Replacing the shift lever
On more than one occasion the shift lever has been moved ever so slightly but enough to put the transmission into manual mode; much to my surprise. This is an '07 XK so I was wondering if it is possible to replace the shift lever with the rotary *** that is on the newer models. Anyone know?
Thanks,
Marvin
Bakersfield, CA
Thanks,
Marvin
Bakersfield, CA
Thanks,
Marvin
Bakersfield, CA
Thanks,
Marvin
Bakersfield, CA
What they ^^^^ said, but as far as swapping out the shifter for the knob, it'd be cheaper and easier to buy a 2010+ than to do all that. There is a TON of stuff that would need to be changed; software, firmware, hardware, transmission...... put aside three months and $15,000 if you want it done.
