Replacing stock XKR exhaust manifolds with headers
Guest
Posts: n/a
Hi,
Does anyone know of any company manufacturing a set of performance exhaust headers to replace the restrictive stock exhaust manifolds used on the Jaguar XKR. The only reference I find when I do a search on the internet, is that Borla company made a set of prototype headers for the car. And also, does anyone know if the stock exhaust headers used on the Aston Martin V8 Vantage will fit the Jaguar XKR chassis. A picture of these can be seen at;
http://www.motortrend.com/roadtests/.../photo_08.html
The factory part numbers for these Aston Martin V8 Vantage exhaust headers are 6G33-5G236-BC for the right side and 6G33-5G232-BB for the left side and the factory prices are $1616.49 and $1432.55
I will greatly appreciate any information that anyone has on this topic.
Thankyou,
James Denno
Thankyou,
James Denno
Im checking with my dealer to see if it will give me warranty issues to change out....if they dont do the upgrade themselves.....chances are they will try to talk me out of it(unless they will do it for me). I would like to have exhaust opened up and not dampered!!!!!!
My local dealer wont install Paramount exhaustsystem, but said that if cat-back only installed.....Im good with warrenty issues. What Ive heard on YTube....http://www.youtube.com/watch?v=Uk3kQGzYxl8 just changing the muffler system is pretty sweet.
Update.....I had a performance shop disable the vacuum controlerand leave exhaust dampening valves open....took about 15min....He called Dealer to see if any issues with doing this and they said only possible thing would be check engine light MIGHT activate and said they would turn it off for free if it came on. So far( two days of driving) no problems....just constant meaty growling from the rear.....sounds awesome when using manel shifting on wheel
Guest
Posts: n/a
the company arden makes a complete exhaust system for jags.
http://luxuryandexotics.net/arden/b-10538.aspx
ORIGINAL: EUROWEST_XJS
Hi,
Thankyou,
James Denno
Hi,
Thankyou,
James Denno
The following 2 users liked this post by whiteSTR:
CleverName (09-04-2020),
Deabs (01-25-2022)
Your stock manifolds are not restrictive.... Unless your swapping the supercharger or stroking the motor out, you really have no need for headers.. At most you could pick up 5-10hp from a set of custom headers, but you would be surprised how good the stock manifolds flow.. By increasing the size of your primary tubes with aftermarket headers you decrease air velocity and in turn decrease your torque, but you gain some/minimal top end power.. The only power to be had is with "full length headers" that match the lengths of all four primary tubes on both sides, BUT stock manifold with short tubes will actually yield more power at lower RPMs.. Its a very specific math equation that Im sure you probably dont want me to go in depth with.. but basically until you find a way to add 50-100hp to your motor (i.e. Intake, Pulley, Twin Screw Blower, ECU tune, Ported heads, etc.) you could potentially do more bad than good by swapping your manifolds to a custom header setup.. My advice would be leave the manifolds alone and play with the cat back setups to get the sound how you want it... but even with exhaust, no back pressure from a straight through exhaust will kill your torque, so dont go nuts with it. Hope this clears up any confusion.. Eric
Holy thread resurrection Batman!
This one's a full 12yrs, are you going for a record!?
On topic my car has the paramount performance exhaust which is from the H pipe backwards with no rear box.
Despite those and the smaller upper pulley and k&n's it's down 17 on stock with a standard tune...which is fine with me as never get to use the full power anyway![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
BrentGardner
28
04-26-2024 03:08 AM
Bcrary3
08-31-2015 11:29 AM
