Replacing Upper control arm ball joint boot
Hi
While preparing my car for winter storage I notices that front driver side upper control arm ball joint boot was cracked. It must have happened recently and I am pretty sure that the ball joint itself is OK. Unfortunately, Jag does not sell the boot by itself and getting a new OEM arm is ~$500. There are a few aftermarket alternatives, but I am not sure about the quality (of the ball joint).
1. Has anyone replaced the boot only and where did you get it?
2. Any recommendations regarding an aftermarket upper control arm? I've heard that Motorcraft makes them for some models but I am not sure about XKR-S.
Received 1,104 Likes
@BlueXKR-S , I do not recall the thread title but if you perform a search in this forum you should find a useful discussion on boot replacement and lubrication.
cheers.
cheers.
steve_k_xk (12-27-2020)
Check my thread here
https://www.jaguarforums.com/forum/x...l-arms-187168/
EDIT: FYI Eurospare is a JLR approved European aftermarket parts supplier
https://www.hotbray.co.uk/eurospare/
BlueXKR-S (12-29-2020)
steve_k_xk (12-29-2020)
There is not a big price difference between the two if you search hard enough, but as I said, Eurospare is JLR approved for aftermarket replacements and my experience how shown their parts and OEM parts appear identical.
I have purchased parts from this company with great experiences.
https://www.rmeuropean.com/Products/...0-MFG1110.aspx
The following 3 users liked this post by jahummer:
howdoyousayjaguar (12-22-2023)
Received 1,980 Likes
“The only exclusion to this program is empty containers with contents that can not be physically returned.”
You might be right, I have not returned oil, just filters and other stuff. But I assumed it would work with oil if you ship it back, not just an empty container. I did not want to mess with oil or brake fluid, so I never tried to ship it. If you look at pictures of returned items they share, they do show oil containers.
Oil is cheap compared to everything else my car needs. I can pay for it
hawaiiansurfster
01-01-2013 07:13 AM
