Request for advice regarding potential purchase of 2010 XKR
Hi all,
I'm new here, but a long time fan of Jags (I'll own an e-Type before I die, guaranteed) and have an opportunity to purchase a "repairable" 2010 XKR. It is said to have "water damage" and require "electrical repair" as a result of the water. Visually the water damage is not visible on the inside or in the engine bay.
I'm a fairly competent DIY guy in that I'm restoring a 1966 mustang and have done many repairs on my daily drivers over the years. I've also bought a repairable before that required electrical repair. Having said that, I've never owned a Jag before, and if they are like other brands, I'm sure there are idiosyncrasies that I've got no clue about.
So, their is obvious risk in buying something like that, but can you guys give me some guidance on things I can do/check/bring/etc. to help mitigate my risk, or decide that I should just walk away? I do have an OBDII reader, but of course it won't have any of the Jag extension codes on it.
Thanks for your time and advice,
John
John
My solicited advice... "just say NO". They may be able to mask the issues for a short time but the electronics and leather won't ever be the same. Unless it's a parts car I'd personally never consider a water damaged car a reliable car regardless how much you think you're saving on the front end. This is not an older mustang, this has MANY computers which are a bit adverse to water... water teens to make the magic smoke leave rendering the car no bueno
Hi all,
John
John
I think you have to ask some questions first:
Does it run?
Are there warnings all over the screen?
Does it throw any codes?
Are all electronic features and systems working? If not, which ones are not?
Any body damage (since aluminum will be expensive to fix)?
How cheap is it, 'cause it's sure not going to be cheap to repair?
Are you going to keep it or try and flip it?
Lots of questions like these and many more should guide your decision.
Great car, by the way, if everything works out.
Does it run?
a PPI would only address issues that are current which is why a flood damaged car is such a gamble... water damage often manifests itself in intermittent issues with the electronics and absolutely destroys/breaks down leather but much of that won't likely be seen on a PPI. You'll never know how much it will be to "make things right" as water damage shows over time unlike crash damage
Older cars, like mustangs and such, are simple mechanical engines with minimal electronics, no leather, but can be prone to rust, newer cars, especially these Jags are packed with electronics and even a slight issue could be quite expensive to just troubleshoot let alone directly address... once you get into computers failing, connectors failing, etc you'll be facing not only large repair bills but probably be chasing that rabbit for the life of the car.
As I've repeated here many times, and read on a Mercedes forum "there is nothing more expensive than a cheap Mercedes", the same holds true here... If you are trying to save money you're looking in the wrong place . I've got mechanical and electronic skills FAR beyond most and I'd NEVER touch a water damaged car. A good example of a 2010 XKR will likely run you @$32K, if you ain't got that cash then look for another car.
Another few reasons NOT to buy a salvaged car - some insurance co's will not insure them. Some banks won't loan on them, selling one once you've realized you got stuck is extremely hard and often takes a while as the market is MUCH smaller. You are simply gambling even if it checks out. Crashed cars are easier to determine IF you know about body work and have it properly checked out otherwise once again you are simply gambling
Good luck
Good luck
Hi all,
John
John
James
Hi all,
A couple of you have apologized for potentially sounding harsh, but please don't worry about that. That's why I'm asking. ;-) However, part of the reason that this opportunity came up is because I have successfully purchased and put into service a 2012 Honda Odyssey that had been crashed in the front left corner. For that repair I had a shop do all the body work and I did the electrical (air bags, controller, some sensors, etc.) and some of the mechanical stuff. To do this, I purchased access to the on-line Honda repair manuals and worked with a local Honda dealer that read the extended OBDII codes for me (for a nominal fee), which allowed me to pinpoint the stuff that remained to be fixed. I just worked the issues one at a time until all the messages were solved. We've had it for 3 years now and so far it's been great.
BUT, that is far different than the damage that water could do to the electronics. That's the big unknown for me and it's clearly a big concern to all of you, which was the reason I asked this question in the first place. ;-)
I may still give the guy a call to get some additional information, but you've made it clear that this is a very risky proposition. So you can feel confident that I'm just going to have to suck it up for another few years until I can save enough to buy one that hasn't been salvaged.
Thanks all.
John
Thanks all.
John
John, best of luck. It's rare to see someone like yourself actually heed advice in the face of excitement and emotions. There are awesome cars. A flood damaged car is a total different beast than a crashed car.
Feel free to hang hear and hear more bad advice from myself and others we need more like you
This one might be worth a "THOROUGH" investigation... only at ~$2500 right now.
https://erepairables.com/salvage-car...eries-16722148
Received 2,048 Likes
