Retractable woes
I have a /008 XKR and while cleaning it I decided to put the top half way up so I could clean behind the cover. As I was in the process of cleaning a neighbor came over with a problem. After taking care of the problem I returned to the car to put the top down and all of a sudden the roof and cover relaxed to where the cover is laying against the convertible top and the top itself fell back forward stopping about 5" from the windshield. I started the car and pressed the toggle to open the roof but nothing happens. Even when I go to close it nothing happens. The indicator on the dash first said the keyless controls weren't present and for me to set the remote into the carrier. The other warning indicator said that the hood wasn't latched. Any thoughts on how to activate the retractable roof?
Thanks for the advice. I didn't see in the index where in the manual it referred to the retractable roof. Found the directions and it worked like a champ! All is back in working order except for the drivers side window when closing the top. All other windows return to close position. Had to replace the battery because it was the original and it was about dead. Wonderful experience! Thank you again.
