Retracting Rear Pistons on XKR
Been a while since I've been so frustrated with a car. Front brakes and rotors went smoothly, outside of the rattle springs. The rears are an absolute nightmare. I cannot get the pistons to retract.
I have:
Put the parking brake in service mode via SDD
Removed the parking brake pull wire
Used the 5mm Amazon universal brake retraction kit
Released the bleeder valve, I read somewhere that it helped, but it didn't, and now I have brake fluid all over the place in addition
Only attached to a socket wrench can I get the piston to even rotate, and it doesn't even seem to retract one bit. Been spinning it slowly clockwise and swearing for an hour and it doesn't look to have retracted at all.
Any ideas?
I have:
Any ideas?
I found this thread, but I didn't have a problem at all when I did mine so no personal insight from me.
https://www.jaguarforums.com/forum/x...e-both-159017/
Well, I finally got the stupid thing retracted. I had to disconnect the brake line, take the entire caliper out, and push down on a socket wrench with all my might. The dust shield "locked" around the piston and is now busted. Any chance that can be replaced, or is it time for a new caliper either way?
Sorry about your troubles, that really sucks! Those rattle springs were a pain although once I mastered getting the first one on (after much cursing) I was able to effortless do the second.
I elected to have my dealer put on the rear pads though, they agreed to put on the rears for $220 with the pads I provided. Your experience probably would have been mine so glad I did.
Good luck, should be able to get a new seal?
It looks like I can get a refurbished kit, not sure if I can DIY, or if I need to buy the refurbished caliper at ~$120
I have the pads and rotors finally done though. Man is the brake pedal very spongy, but didn't have time to do a bleed after this took all day and will have to save that for next week. I assume I let in a ton of air removing the calipers, so that should definitely help.
You don't note your year, make, model and which brake package you have but if memory serves, when I had my Super V8, it had Brembo's and I was able to replace the rubber. I had the same problem as you and once I completed the "piston retraction from hell", movement was fine.
If it's me, I'd reconnect the caliper and check the movement and manually retract again. I think it will be easier the second time around.
OK this is the part that I used on my SV8. I can't see where it lists your car in the details so I can't confirm (set is right at the top under deals) I say this because it says it fits an 07 XKR but I don't know how it can if it fit my Brembo's. Perhaps a call to the vendor?
https://www.ebay.com/b/Brake-Caliper...Coupe%202-Door
I saw nothing in the EPC.
Here's another that says it fits
https://www.ebay.com/itm/Disc-Brake-...C+Supercharged
BTW, it's not about the car model so much as the piston size so I think the piston is 45 mm, it should fit.
And another. Guessing only that S-Type and XKR used the same brakes:
https://www.summitracing.com/parts/c...pe?prefilter=1
silvertonesx24
05-06-2020 03:11 AM
