Retrofit heated steering wheel - possible?
If the wiring is not in the steering column then I think you would have to replace the column. You would also need to reprogram the nav. system to have the steering wheel heater control on the home screen and I would also bet you need the heater relay to complete the installation. So you may have to replace the steering column and the nav. screen if it is different from the non-heated wheel option.
8bit (12-24-2015)
carelm
03-01-2016 06:39 PM
