Right front headlight
Hi
The motor that swivels the standard beam on my XK8 150 right headlight is broken - point to the left. When I try to swivel to the right, it gets to a point and then goes no further,
What parts do I need? Motor, headlamp glass (I'm sure mine will break when I try to remove it), seal around glass anything else?
Or do I need to purchase a complete headlamp assembly comprising all parts - high beam, standard beam, indicator, etc.
Where can I buy these parts and approximately how much will it cost me?
RegardsLeonard
RegardsLeonard
The following 2 users liked this post by Cee Jay:
80sRule (11-28-2021),
steve_k_xk (11-28-2021)
The insulation on the wiring gets brittle and just cracks off. I had to repair my left headlight since it got a lazy eye in 2019 or 2020. I baked the headlight a bit that softened the adhesive that holds the lens to housing. Then took it apart.
The wiring for the motor was all chipped off. They had like five or six very fine wires, like inside an RJ45 cable. I noticed one was just completed broken in half. I replaced the wires with REALLY fine gauge ones one at a time. They are supposed to go in this grooved channel but they were a little thick and I had to mess with it a bit but made things Gucci. I put all the bits back into the housing but left the lense off. Popped it in the car and I don’t remember if I needed to use SDD to do anything but was able to confirm the success of the repair. Then I put the housing back together and installed into the car.
The following 9 users liked this post by 80sRule:
Bill400 (11-29-2021),
Cee Jay (11-28-2021),
DorsetJag (11-29-2021),
kj07xk (11-28-2021),
panthera999 (11-30-2021),
and 4 others liked this post.
Where are you based?
To close the loop.
Jaguar South Africa quoted me the equivalent of $3,250 for a new light, this after assuring me that my problem couldn't be repaired.
My Jag specialist has just repaired the light for around $470.
Moral of the story. Find yourself a Jag specialist in his mid 60s who joined his father's Jag business when he was still a youngster.
There is nothing my guy doesn't know or can't fix. I made him promise he'll outlive me :-)
Leonard
Leonard
lstoch (12-02-2021)
