Roof wont go down
I just upgrade to a 2007 XK8 from an 05, very pleased. I just changed the battery which helped my instrument panel but now my top wont go down and I get the luggage cover out of position message, Much written about this but having to take all the panels out and the cover and seems something just isnt back in place properly. The cover has been played with for over an hour with no success. There are a few screws missing for the panels but they are snug. Any opinions please? With the 05 there is a reset touching the battery cables but unsure fro the 07.
Welcome to the X150 Forum! You'll find lots of knowledgeable and helpful members here. Almost every question you can think of has already been asked and answered, so learn to use the Advanced Search function for advice.
Forum member WhiteXKR (Steve, the Jag Wrangler) is the convertible top guru. You probably already know him from the X100 (XK8) Forum and his remote control top kit. He has one for the X150 and I highly recommend it.
See this thread from 2015 and follow WhiteXKR's advice. Make sure that your battery is fully charged.
https://www.jaguarforums.com/forum/x...please-146325/
Good luck!
Good luck!
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Yes and I appreciate that there si a lot of info, in my case to much. Im mobile with only my phone driviing this car home fro California. Yes Im cheating a bit but am in a tough spot on the road. I appreciate the comment about the clip but arent understanding where the clip is, Im assuming the left of the cover end that slots in?.
I should also add that the rear windows wont go up. I understsand from reading its because of low voltage and then the battery change for the roof. I did do the reset but it hasnt worked. The mans manual said I would have to drive for 14 kms. I realize much written but again looking at a phoen screen and doin my best.
Stuart S (09-26-2020)
See these old threads. Read them in their entirety before you do anything.
https://www.jaguarforums.com/forum/x...-re-set-55684/
https://www.jaguarforums.com/forum/x...earned-130852/
Cee Jay (09-27-2020)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1494x1494/divider_clip_resized_ec9912a42df3c5591a11ee6db9b187badd39a197.jpg)
Here is a picture of the black metal divider clip at the end of the divider cover rail. If it is missing, and you have the cover warning message, the top will absolutely not work. Check carefully for it in the trunk if it is missing. It may have fallen out and be lying somewhere in the trunk.
Stuart S (09-27-2020)
Here is a pic of the runner end, looks a little different than the one provided but I see there is no insert if there should be one? Looked everywhere and only found a clean small peice of plastic an dits not discolored like this end of the runner.. If Im missing it can I substitute with anything metalic?. Also if I can have some further help please. I have the top down but it wont lock down and pops up about an inch. NOthing in the manual, Thanks to all that have replied.
![](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
