Rotating grinding noise only on right turns
Hello everyone,
I'm newly registered to the forum, having always enjoyed maintaining my own cars. Browsing this community has proved invaluable when it comes to troubleshooting issues on the XK. So firstly, thank you for all your contributions!
I've noticed that my late 2007 XK X150 4.2 has been making a metal rotating grinding noise that only occurs when turning right round bends or roundabouts and varies in intensity depending on the speed and degree of the right turn (I have attached an audio file of the noise when going round a roundabout). The noise doesn't occur when turning right very slowly, such as when parking. It's more audible in person than in the audio recording, though you wouldn't hear it over the radio so I don't know how long it has been going on for.
I believe the noise to be coming from the front left side of the vehicle, yet I'm unable to pinpoint the issue. I've checked the wheel to see if there was any play in the bearing, taken the wheel off and inspected the rear brake shield to make sure there was no contact with the disc. As well as removing the calliper to check the brake pad condition (less than 30% worn).
Has anyone else had this noise on their XK and fixed it or knows what it could be?
Thank you very much for the help
XK Right Turn Noise.mp3
Welcome to the forums XK4.2,
(Your post was automatically locked for moderation because of the attached audio file. I've unlocked it so members can now see it.)
I can't hear it too clearly because of the turn signal sound but you've already eliminated the first things I'd check. Moving on from bearing or brake as possible caues, check the metal heatshields haven't torn through the fixing bolts or the plastic undertray worked loose.
To the OP : sorry about your problem...I'm interested in this topic as well, as, in my case, I hear something when steering and braking at the same time, for instance when making a turn at a crossroads... I wouldn't call it a grinding noise, but it sounds like something is moving down there that shouldn't be...
XK4.2 (06-13-2022)
I have further checked underneath the XK and there are no loose heat shields, trays etc. I also took the caliper and disc off a second time and again there are no issues with the pads, disc (no lip and less than 3 years old). Only thing I did notice is that the disc is missing its two retaining circlips, but this should not be any issue as once the wheel is on the lug nuts hold it firmly to the hub.
I have attached a new recording of the noise going right round roundabouts on three separate occasions. Does anyone know what this noise could be? I'm 90% sure the sound is coming from the front left wheel, which has no play in the hub bearing when jacked up.
I tried listening and there is too much superfluous noise to single out what I'm supposed to be listening for. Maybe just me as I'm mostly deaf but if you could isolate the sound by telling us at what minute/second the issue occurs may help. Also find a smoother road, eliminate the turn signal so all we hear is car would be helpful.
The exact times the noise occurs are at 12 seconds, 32 seconds and 52 seconds. As you can hear it’s slightly different every time as the noise changes depending on the speed of the right turn and resulting load on the left side of the car.
Sean W (06-18-2022)
XK4.2 (06-26-2022)
Enzo Valetti
06-01-2020 06:45 PM
NewLester de Rocin
General Tech Help
01-09-2018 10:07 AM
al_roethlisberger
04-05-2016 10:12 PM
08292
01-06-2016 06:01 PM
