Rough idle at stop sign and then "Limited Performance" dash light
On the way in to work this AM at a stop light I noticed low RPM and an unusually rough idle. Put it in neutral to goose the gas a bit and back to drive to pull away, once up to speed things were fine. This repeated itself at the next couple stop lights and then the "limited performance" engine light came on. I was able to get it into the parking garage, pop the hood, nothing smelled odd.
Any ideas on this one or should I just call the dealer and take it in?
Received 2,626 Likes
Im interested in hearing what the issue was as well. Thanks
Byte Me (and thank you for giving me the opportunity to start a correspondence with "Byte Me)...
I've got a 2010 XKR with similar, though not identical, symptoms, including the Reduced Performance warning.
How did your situation resolve? What was the issue?
Thanks in advance...
