RPM varies a bit at constant speed
I have noticed that when I am cruising for example 35mph (a bit over 1500RPM) the engine speed varies a bit in a rhytmic fashion. The cycle is something like 2-3 seconds. Not much, perhaps 100RPM, but it sounds irritating. Is this normal, and if not, what to look for?
Mine does it too on occasion as it warms up from a cold drive away, say 3-4 minutes into the trip around 35 mph. Just enough of a tone change to look at the tach and see the needle wandering maybe 50 rpm. I think it's just a blip in the warm up cycle where the o2's aren't warmed up to fully reliable yet but the puter's reacting to them.
I think you mean the torque converter, not transfer case - there is no transfer case in the 2004 XJ8. My 2004 XJ8 had the symptom you are speaking of. But the oscillation in rpm disappeared after the engine and transmission were properly warmed up so I did nothing about it - a minor issue in any case. I do not think this is the same thing that the OP is describing.
