Rubber doughnut on propshaft
Old 05-19-2014, 11:03 AM
milleniumaire's Avatar
Cambo351, Thanks very much for supplying the details of the S-Type rubber doughnut. My dealer ordered one and compared it to the part on my 2007 XKR and they were identical. Even the model numbers were the same! The part was around £65+vat and with labour that was just over £200, so a lot less than over £1000+fitting for a new drive shaft.
It's pretty poor of Jaguar to not list this as a separate part for the XKR when it clearly exists.
For anyone interested, as Cambo351 identified, the part number for the 'rubber doughnut' or Jurid Coupling is C2C12747. The 2007 XKR uses the same part as the S-type.
Thanks to everyone who contributed. Result!
The following 7 users liked this post by milleniumaire:
04XK8Conv (04-18-2016), Big Papa G (09-18-2021), Cambo (05-19-2014), kj07xk (04-18-2016), Ngarara (05-20-2014), Panthro (04-28-2016), u102768 (05-19-2014) and 2 others liked this post. (Show less...)
Old 05-19-2014, 08:17 PM
Received 4,458 Likes on 2,427 Posts
I love happy endings, glad it worked out for you.
Old 04-18-2016, 01:00 PM
04XK8Conv's Avatar
Just ordered a replacement for my XK. Thanks for posting this information! Absolutely ridiculous that Jaguar only lists this as part of the propshaft assembly. I'll have to check this against one from my Discovery II after I swap it out. It "looks" really close...
Old 04-18-2016, 04:40 PM
JagRag's Avatar
For those asking the about the purpose of this item:
https://en.wikipedia.org/wiki/Giubo
kj07xk (04-18-2016)
Old 04-18-2016, 06:48 PM
flyc2c's Avatar
I saw a Mercedes S class that had a rubber flex disc fail. All but one bolt ripped out of the coupling. The flinging driveshaft made an oval of the transmission tunnel and set off every airbag in the car.
Old 09-18-2021, 10:45 AM
Big Papa G's Avatar
This is awesome news, I have exactly the same issue so the fact I dont have to buy an entire driveshaft is awesome! Thanks all for posting the info!
Old 09-18-2021, 12:10 PM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
You have to watch out for the dates of posts and threads, this one is 5-1/2 years old. An apology for resurrecting a thread is usually expected, then any continuation which is relevant is fine and great. Just shows you realize the thread is old.
I'm glad you found the info you needed to fix your problem though.
  #28
Old 09-18-2021, 03:53 PM
Big Papa G's Avatar
On a similar topic, I have a 2009 XKR x150 (4.2L), and the centre carrier bearing for the prop shaft has given up. Again, it seems Jaguar only do this as a complete unit, rather than supplying the bearing alone. I was wondering if any of the older model bearings can be used, perhaps from the x100 models. If not, are there any after-market manufacturers out there that might be able to supply it? It seems madness buying an entire prop shaft assembly just for the bloody bearing!
Old 09-20-2021, 04:15 AM
xalty's Avatar
Received 1,061 Likes on 852 Posts
use the part for the tbird and LS or the ebay specials for the x350. both should work
XW4Z-4800-CA
AKA
SKF HB88517
https://www.ebay.com/itm/Jaguar-S-Type-Driveshaft-Center-Support-Bearing-XJ18-X350-XJ350-1999-2008-/133482224508?mkcid=16&mkevt=1&_trksid=p2349624.m46 890.l6249&mkrid=711-127632-2357-0
  #30
Old 09-20-2021, 07:44 AM
panthera999's Avatar
For those googling to find this, it's called a giubo (correct spelling) or guibo, in the US and other countries, after the original Italian company that developed them. Also a flex disk. And of course, the propshaft is googled as a driveshaft in the US.
Glad to hear it was found as a discrete part.
Chris32111
09-20-2021 07:39 AM
makjohannesson
06-22-2015 06:25 PM
RichardPhuket
11-24-2014 11:19 PM
RichardPhuket
11-03-2014 02:51 PM
toronadomike
09-30-2013 06:02 PM
Quick Reply: Rubber doughnut on propshaft
