Running 305/30-20 in the rear for XKR-S?
I have XKR-S and considering getting 305/30-20 in the rear instead of stock 295/30-20. Can people with XKR-S comment if there are any rubbing issues when suspension is fully loaded or unloaded? I've seen several people on this forum with this setup and I appreciate your feedback.
BlueXKR-S (12-14-2017)
Cambo is correct. Use Tire Rack’s website to find a tire that has a wider tread width than what you currently have. P-zero tires have a wider tread than most. If you are not careful by going from a P-zero in 295 size to say a Bridgestone or Continental tire in 305 size you could actually end up with a narrower tread width. Tire Rack shows actual tread width and section sizes under the specifications tab. You will be amazed at the tread width difference for the “same” size tire.
Thanks, did not know that
I think you could get away with a 305 Pirelli and have a good look. As Cambo stated, I would not recommend a spacer and a wider tire. The original jag spec pirelli is 11.4" tread width.
Similar 295's are typically narrower than that.
Staying in a similar weight category you could hop onto a 305 Ferrari spec tire and have around 12"tread width. I wouldn't go much wider than that as I think you would you not have the ideal geometry for the tire to perform properly without stepping up to a wider rim.
The only compromise to this is, tire diameter, its going to be about an 1-1.4" which can compromise dynamics in the programming as this impacts rev/mile(km).
The other option is an Aston spec in 305 but then Pirelli spec tire is actually only 10" tread width.
I've done this with my XKR stepping up from a 285 to a 295, but I have not changed the XKR-S yet.
Panthro (12-16-2017)
1 Post
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/dsc07326_e4771bab307ae5a0b694590b1a9ec75d6df5b12e.jpg)
Old timers will remember the baseball bat method used back in the day. Really, no kidding. Why did we use a baseball bat? Because the results were hit or miss. No so with this tool; if I can do it, so can anyone who can read and follow directions.
Really easy to screw it up using a bat. The fender roller tool makes it really easy to do it right. Much better control over the arc and incremental pressure. It'll cost more to fix a bat mistake than to rent the tool. Your car, your money, your choice.
draguarxkrsgt
04-27-2017 03:55 PM
vincent661983
05-19-2014 11:35 AM
