Safe to Use New Mahle Fuel Filter With Small Dent?
I recently purchased a 2008 XKR Portfolio coupe with just over 60K miles. The car didn't come with a service history, so I am changing fluids, filters, and worn suspension components. I'm content to use non-OEM parts if there is a cost savings and the quality of the aftermarket part is at least equal to the OEM part.
Through the power of the internet, I was able to track down a Mahle KL598 fuel filter for about half the cost of an OEM Jaguar fuel filter. Unfortunately, when I opened the Mahle box, I immediately noticed that the Mahle labeled fuel filter had a 5/8" dent along the edge of the inlet side.
![Name: s2mQ7aT.jpg
Size: 42.5 KB](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/224292d1683065966-safe-use-new-mahle-fuel-filter-small-dent-s2mq7at.jpg)
The web based vender from whom I ordered the filter is now showing out of stock for Mahle fuel filters. So exchanging it doesn't appear to be an option. Would you consider this fuel filter safe to use? Would you feel comfortable using it in your own car?
Best Regards,
![Name: s2mQ7aT.jpg
Best Regards,
V7Sport (08-10-2022)
Thanks for the sanity check, gents. I didn't think it would be an issue, but I would really hate to be wrong with pressurized fuel.
There was no damage to the outer shipping box, and the vendor used plenty of padding. The Mahle packaging/box is a little tattered around the edges, but was tightly sealed with clear tape. There is a corresponding divot in the Mahle packaging/box. It appears it was dropped (in it's original box) somewhere in its life prior to shipping.
I'll install it later today.
Best Regards,
Best Regards,
GGG (08-10-2022)
