Safety belt not retracting when engine on
Hi all,
Delighted I found these forums, they have been extremely helpful. I recently bought an 2010 XK, left hand drive, c. 50k mileage. Really happy with it but have an issue with the drivers safety belt.
When the engine is on, the belt does not retract at all. However before I turn on the engine or immediately when i turn it off it works perfectly. Seems very counterintuitive to me. Given the impact the engine status has on it i don't believe its a typical problem with a twisted belt etc (but I am open to be corrected).
Has anyone encountered a similar issue or be able to advise on how I can go about figuring it out?
Many thanks!
Many thanks!
Welcome to the forum dermo,
I've moved your question from General Tech Help to X150 forum. This is the place to post technical questions about your model.
dermo (06-12-2018)
Try this: sit in the driver's seat but do not put your foot on the brake pedal or touch the start button. Pull the seat belt out all the way until it stops but don't latch it. Hold the belt in the fully extended position.
Press the start button first and then step on the brake pedal. The car should start and the warning chime should sound.
Latch the seat belt and then release the belt. The chime should go off and the belt should retract. If not, there's probably a bad sensor and it's time for your Jaguar dealer or qualified indy technician to diagnose and fix it.
Let us know if that made any difference.
dermo (06-12-2018)
Hi Stuart
Thanks so much for the detailed reply. I don't know how or why but that helped significantly! Now when I unlatch (unbuckle) the belt it retracts properly (regardless of whether the engine is on or not). So now the only time it doesn't retract is when the engine is on AND the belt is latched - at least now if it becomes very slack I just have to unlatch and re-latch to reset it, not ideal but workable. Is there anything further that can be tried now or is it only a dealership visit that will fully fix it?
Thanks again
Thanks again
dermo (06-13-2018)
Hi Stuart
Thanks again
Thanks again
I'm not a mechanic, but I suspect that your seat belt has a faulty pretensioner. That's the device that locks the seatbelt tight in the event of a collision. You can have your dealer confirm my suspicion and compare their repair cost to this independent internet repair service: https://www.safetyrestore.com/jaguar...lt-repair.html
Let us know what you find out and decide to do.
dermo (06-13-2018)
