Sagging Door Panel Fix
Old 12-02-2017, 05:33 PM
jbretthorton's Avatar
Default Sagging Door Panel Fix
Thought I would share this with the group...
My drivers door panel leather over the past year has started to come lose and sag, which has been driving me crazy as the interior is almost perfect in my 07 XK. So I decided to fix it..... Seemed somewhat difficult to remove the panels themselves from the door panel, so I thought possibly the fix could be as follows:
I had a large syringe with an 18 gauge needle, I made up a batch of Elmers glue and about 10% water mix. I then injected the leather door panel at the top edge in between the stitches and the two adjoining seems, careful of course, I ended up using about 40 ml of the glue mixture, your mileage may very depending on the severity of the delam. I let the mixture dry about 10 hours then reinstalled! Looks almost perfect! The only thing you can sorta see is the tiny holes from the needle, but these are almost imperceptible...
Attached is the completed fixed door panel
The following 8 users liked this post by jbretthorton:
apost8n8 (10-24-2020), guy (10-24-2020), jahummer (12-04-2017), ralphwg (12-03-2017), robtroxel (12-03-2017), Sean W (12-02-2017), shemp (12-04-2017), winstonsalemncxk (12-03-2017) and 3 others liked this post. (Show less...)
Old 12-02-2017, 06:23 PM
Stuart S's Avatar
Received 6,285 Likes on 3,449 Posts
Nicely done, and saved a lot! Nothing beats the feeling of accomplishment when a DIY fix works.
jbretthorton (12-02-2017)
Old 12-02-2017, 10:04 PM
Sean W's Avatar
Received 4,219 Likes on 2,367 Posts
I did the same thing on the dash where I was seeing some air pockets. I just attached a long thin tube to a can of automotive 3m adhesive. Worked like a charm. I slithered the line in once I removed the center speaker grill.
The following 2 users liked this post by Sean W:
jbretthorton (12-03-2017), robtroxel (12-03-2017)
Old 12-03-2017, 03:15 AM
u102768's Avatar
Received 1,490 Likes on 908 Posts
I have the same issue so do you have any tips on removing the speaker grill because it seems to be quite delicate and I have heard stories of people breaking them and seen pictures of bits snapped of them?
Also, is there anything substantial under the leather covering to stick it to or does the leather separate from the foam?
Old 12-03-2017, 08:46 AM
robtroxel's Avatar
Not sure by your posting if you did remove the door panel or glued it in place?
Thanks for sharing this idea
Old 12-03-2017, 10:47 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
Would be nice to see the before picture just to give us some perspective on what the panel looked like.
viper1996 (12-23-2020)
Old 12-03-2017, 12:35 PM
winstonsalemncxk's Avatar
Looks great! I hope I don't have this issue, but I appreciate the solution you've posted!
Old 12-03-2017, 07:54 PM
Sorry no before picture.... But pretty easy to google and find this problem, Here is a picture of another door, very similar to what mine did... (Mine was driver door though)
I removed the door panel from the car, to make easier to work on.
Did not have to remove the speaker cover though...??
Attached Thumbnails Sagging Door Panel Fix-front-right-passenger-door-interior-trim-panel-c2p12302leg-jaguar-xk-xkr-2007-302152533403.jpg
The following 2 users liked this post by jbretthorton:
jagtoes (12-03-2017), peterv8 (12-03-2017)
Old 12-03-2017, 07:57 PM
The leather separated from the foam, If even there actually, I really could not feel much of any foam between the leather and the door panel.
I just injected it in several places, then with my fingers, pushed the glue mass where it need to go. Pretty easy actually.
Old 12-03-2017, 08:01 PM
So just a heads up to people...
My door panel originally (When I got the car) was perfect. When I initially removed the panel to replace a speaker, I pulled up on the panel obviously to hard, causing it to flex a little, which in turn delamed the leather from the panel...
So.... Be careful when you remove your panels!!
Old 12-03-2017, 09:34 PM
Sean W's Avatar
I'll snap a pick of the speaker cover removed so you can see the lift points. I just used a plastic prying tool and yes you want to take it slow.
The tubing is bugging me. I bought the 3M adhesive at the auto parts store and then just asked them (I think) for some tubing. Concept is like the red tube the comes with WD 40 but the tubing I got was clear and flexible but same diameter as the WD40. I had air pockets an it just slid under very nicely I sprayed quite a bit and pushed down and outward in all directions.
I also taped plastic over the top of the leather in case the tube came loose. That proved to be worthwhile.
u102768 (12-03-2017)
Old 12-04-2017, 06:55 AM
I don't know how you could use "tubing" in the door process as the seam is very tight. Even using the 18 gauge needle, I had to be careful but forceful to get it through the seam
Old 12-04-2017, 12:21 PM
Sean W's Avatar
I would remove the door card and approach it that way. For the dash, which is what I was alluding to, the leather ends under the speaker cover. It isn't wrapped around it.
jbretthorton (12-04-2017)
Old 12-04-2017, 12:25 PM
Rgr
Old 12-04-2017, 12:40 PM
Sean W's Avatar
Speaker is on its side. My thumb is in the front middle. You can see the white clips. That's how it's held in.
And this is what I used to pry it
And this is my 11 month old Grandson from about a year ago looking to kick some ****. No reason I suspect.
u102768 (12-04-2017)
Old 12-05-2017, 01:06 AM
trkyam's Avatar
Where did you buy the syringe and needle to do this?
I attempted this with a smaller needle and failed hard..
Old 12-05-2017, 06:16 AM
I had these at my shop for years, so sorry, I do not remember
Old 12-05-2017, 07:31 AM
pwpacp's Avatar
Not sure if the size works for this but needles and syringes can be purchased at farm supply outlets like TSC or Quality Farm & Fleet. I use to buy them there for use with Goo Gone to remove golf club grips. Worth a look.
jbretthorton (12-05-2017)
Old 10-23-2020, 10:29 PM
dag82's Avatar
Hello
question once you remove the door panel, is it possible to reach the detached area leather from the inside as opposed to getting an 18 gauge needle and attempting to go in through the seams??
Thanks for any & all advice
-dag
Old 12-22-2020, 11:09 AM
Sean W's Avatar
Originally Posted by dag82
Hello
-dag
Yes. A couple things to note. There's no foam backing that I could see on the door card leather. It's appears to be just leather on plastic. You can do it with the panel in place but still need to pull the panel away from the door a bit.
I just did mine. I have the panel off as I'm replacing the speakers and adding a crossover but thought I'd post a video. Note I misspoke in the video on the dowel rod. It's 1/4", not 1/8"
The following 6 users liked this post by Sean W:
Bill Mack (12-22-2020), LoudHogRider (12-24-2020), peterv8 (12-22-2020), Stuart S (12-23-2020), V7Sport (12-24-2020), XKRAU (01-02-2021) and 1 others liked this post. (Show less...)
Quick Reply: Sagging Door Panel Fix
