Sagging Door Panel Fix
Thought I would share this with the group...
My drivers door panel leather over the past year has started to come lose and sag, which has been driving me crazy as the interior is almost perfect in my 07 XK. So I decided to fix it..... Seemed somewhat difficult to remove the panels themselves from the door panel, so I thought possibly the fix could be as follows:
I had a large syringe with an 18 gauge needle, I made up a batch of Elmers glue and about 10% water mix. I then injected the leather door panel at the top edge in between the stitches and the two adjoining seems, careful of course, I ended up using about 40 ml of the glue mixture, your mileage may very depending on the severity of the delam. I let the mixture dry about 10 hours then reinstalled! Looks almost perfect! The only thing you can sorta see is the tiny holes from the needle, but these are almost imperceptible...
Attached is the completed fixed door panel
jbretthorton (12-02-2017)
The following 2 users liked this post by Sean W:
jbretthorton (12-03-2017),
robtroxel (12-03-2017)
I have the same issue so do you have any tips on removing the speaker grill because it seems to be quite delicate and I have heard stories of people breaking them and seen pictures of bits snapped of them?
Also, is there anything substantial under the leather covering to stick it to or does the leather separate from the foam?
Thanks for sharing this idea
Sorry no before picture.... But pretty easy to google and find this problem, Here is a picture of another door, very similar to what mine did... (Mine was driver door though)
I removed the door panel from the car, to make easier to work on.
Did not have to remove the speaker cover though...??
I just injected it in several places, then with my fingers, pushed the glue mass where it need to go. Pretty easy actually.
So just a heads up to people...
My door panel originally (When I got the car) was perfect. When I initially removed the panel to replace a speaker, I pulled up on the panel obviously to hard, causing it to flex a little, which in turn delamed the leather from the panel...
So.... Be careful when you remove your panels!!
The tubing is bugging me. I bought the 3M adhesive at the auto parts store and then just asked them (I think) for some tubing. Concept is like the red tube the comes with WD 40 but the tubing I got was clear and flexible but same diameter as the WD40. I had air pockets an it just slid under very nicely I sprayed quite a bit and pushed down and outward in all directions.
I also taped plastic over the top of the leather in case the tube came loose. That proved to be worthwhile.
u102768 (12-03-2017)
I would remove the door card and approach it that way. For the dash, which is what I was alluding to, the leather ends under the speaker cover. It isn't wrapped around it.
jbretthorton (12-04-2017)
jbretthorton (12-05-2017)
Hello
question once you remove the door panel, is it possible to reach the detached area leather from the inside as opposed to getting an 18 gauge needle and attempting to go in through the seams??
Thanks for any & all advice
-dag
-dag
I just did mine. I have the panel off as I'm replacing the speakers and adding a crossover but thought I'd post a video. Note I misspoke in the video on the dowel rod. It's 1/4", not 1/8"
The following 6 users liked this post by Sean W:
Bill Mack (12-22-2020),
LoudHogRider (12-24-2020),
peterv8 (12-22-2020),
Stuart S (12-23-2020),
V7Sport (12-24-2020),
and 1 others liked this post.
