Sat Nav antenna location xk convertible
Hi, I have searched for an answer to this so forgive me if it was there all along.
I now have a lovely snarling 2008 XK convertible to keep my XJ 6 company, but I am having trouble with the sat nav, the little icon always has a slash through it so I am guessing the antenna is not working or is disconnected. Problem is I cannot locate it! I think its supposed to be under the parcel shelf, should it be easily visible or is it hidden?
Cheers Phil
Cheers Phil
Cheers Phil
Cheers Phil
Richard
Several causes are possible including, but not limited to, a loose connection and a bad GPS antenna.
See:
https://www.jaguarforums.com/forum/x...solved-239884/
https://www.jaguarforum.com/threads/...at-nav.109097/
See:
