Scared stiff to try this!
Hi - Had my fab car for 5 months but now in UK winter is approaching and not taking my car out over the winter. I have purchased good quality trickle charger (and used same on my Merc CLK) but can't even find the battery on my XK! Hand book has shown me separate lugs in boot for '+' terminal and under wheel cover for '-' terminal. But scared stiff to use these in case I fry my little beauty.
Anyone else used this location for a trickle charger over winter time or for 3-4 months
also what is best position for auto gearbox? N or P, concerned about brake binding. Car is under an all weather cover and is underneath an open sided tractor shed so not warm and cosy but is dry.
Many thanks
Many thanks
The positive + and negative - you describe that are listed in the manual are the locations you can use to attach the charger. Just follow the instructions and you should have no problems. The battery is behind a cover that you reach from the boot. As for parking you should leave it in P , park.
Know nothing (11-27-2017)
Other things that come to mind are: placing a vapour barrier on the floor under the vehicle such as a thin plastic film, or painter's cloth to reduce moisture unless your garage is heated.
Unless you're planning to drive the vehicle at weekends, it may also be best to purchase a quality cover to keep contamination off the paintwork.
If rodents or other animals seek refuge in your garage, some on this forum add scented clothing dryer papers around the engine compartment as a deterrent.
Also doesn't hurt to park them on a plastic painters tarp (clear 3 mil will do). This prevents moisture from leaching up from the concrete floor.
Lay dryer sheets on the floor inside the car and in the engine bay. Put steel wool or rags in the exhaust tips. These tricks will keep mice away. Doesn't hurt to scatter moth ***** on the tarp outside the car either but some folks don't like the smell. If you're storing it away from your home garage, shouldn't be an issue.
Leave your self a note on the driver's seat to remove the steel wool/rags and dryer sheets lest ye forget.
Ok Ranchero50 - thanks for that - hoping the farm cat will keep the rats at bay, they're bigger targets than the mice and a bit slower so he can just about manage them - but I'll put a few traps down as well - would love to drive out on those winter days - I was pretty pleased at Goodwood this year when got beached in a really muddy car park and came through unscathed even after a tow out
Was intending to take trickle off every couple of weeks and run the engine even if didn't drive off the farm but appreciate a run is better than a static engine tick over - Cheers
Exercising the car vs just running the engine will net better longevity. It's the rubber bits in the car that get hard and then crack / fail once they're moving again that causes grief.
At my buddy's farm some of the rats are as big as the cats. I shoot them with an air rifle every couple weeks. Nasty things.
So moving the car and giving it a gun down the motorway sounds like a good routine - pure joy - just love this car - puts a smile on my face as soon as I get behind the wheel and laugh with joy when I put my foot down!
Our cat wouldn't cope with the rats that size even though he's a big guy - perhaps I'll give the cat an air rifle !
I have heard from others that mint oil on a cotton ball inside the car is great rodent deterrent. Make sure the cotton ball is not directly touching anything inside the car.
@Know nothing - thanks on the cars. The XE and Vantage are my current ones. Hope to have a Rapide replacing the Vantage by spring.
Interesting what deters the little blighters, always wonder how people discover these things work - thanks for that
The XK60 I have was the closest I could get to an Aston - still hoping to get there one day - good luck and have fun shopping for the new one - performance must be awsome - I saw one at Goodwood this year for sale and was sorely tempted to splash out but will have to wait for another day
Yup that's pretty damn awesome ! - thanks for the photo. When I went to buy the XK there was an XK8 there as well, I wanted a car that made a nice noise so got the sales guy to start them both and rev the engines - sold the XK to me because of its noise. Took it for a test drive and he knew I wasn't going to be a tough sale with a huge grin on my face. With all the bits and bobs deactivated on the Vantage it must be like going back to the good old grandprix days before the hybrids came in, with that fab noise you can only get from petrol engines. Actually, and this sounds sad, when I see someone with an Aston out and about and parked, I ask them to start the thing up just so I can listen to it - they always oblige - nice guys these Aston owners ! (not sure what HVAC is)(or VAP decats but can guess at the effect of removing the fuse) - Enjoy
Know nothing (11-28-2017)
