SDD Help
I’m planning to install Cambo’s Carplay system in my ‘09 XK. I need to have the auxiliary audio input activated. I’ve called 3 dealers in the area and I must be speaking a different language...they either don’t know what SDD is or tell me it’s not possible. The independent shops I’ve called don’t have SDD, they all use something called Autologic. I’m in suburban Philadelphia, PA. If you can help me with this by directing me to a shop with SDD or if anyone has it, I would be grateful for your help...
From what I read, Autologic can do what SDD does. So if someone has it and can turn on your Aux input....
https://www.vglequipment.be/en/diagn...ar-diagnostics
arenaej (08-07-2020)
This from Autologic Jaguar Diagnostics:
Autologic JAGUAR is a genuine alternative to 'IDS', often providing quicker diagnostics, coding and programming than other the JAGUAR diagnostic tools. Additional features of Autologic JAGUAR over other diagnostic tools include fitting aftermarket components and an increased number of retrofits.
Standard coverage
All systems and functions covered Autologic is the only aftermarket diagnostic tool to offer OEM-level functionality
ECU Flash programming Necessary when a blank unprogrammed ECU is installed. No other aftermarket diagnostic tool offers full flash programming capability.
ECU Coding ECU is configured with extra parameters that correspond to extra vehicule specification.
Service Functions For each brand, Autologic offers a comprehensive range of service functions. Diagnostic Trouble Codes (DTC's) Autologic operates, with manufacturer' Diagnostic Trouble Codes (DTC's - also known as fault codes), providing full accurate diagnosis. Live Data/Actuations This function of the Autologic aids the user through remonving live data and carrying out component actuations for ease of diagnosis.
Data logging Records communication between Autologic and vehicle ECUs. Informationobtained is used to help diagnose software issues in an unrecognised ECU of fault code.
It seems pretty comprehensive, I’ll report back after trying it on Monday...
Standard coverage
Cee Jay (08-07-2020)
This would indicate it can change CCF files:
- Control module programming - with complete flash programming capability, Autologic also allows the restoration of configuration data, restoring a corrupt vehicle to the specification it left the factory
- Car Configuration File (CCF) data - Autologic provides a greater freedom to allow customers to personalise vehicles
I have never used AutoLogic, but I know a workshop that has it, unfortunately they are 1400kms away from me.
From previous discussions with them regarding Land Rovers, I know that the CCF provide by AutoLogic is not going to be "complete" they did not give access to everything.
I did already ask him about the AUX input in an X150, albeit for a 2010, as those can't be done with a standard SDD. But the field in the CCF is exactly the same for all X150's.
It seems that either AutoLogic changed the name of the field, or they have it completely wrong, or they left it out. I can't tell from here.
In SDD the required field is called 'Audio auxiliary input' and you are changing it from 'Not Fitted' to 'Fitted'.
In AutoLogic the only option displayed in the CCF close to this is “auxiliary audio input (inc. mobile phone)”, the two options are “no media accessory usb” “or media accessory usb”.
So either they changed the name, or they have it wrong. Only one way to find out...
Also within a complete CCF there are two fields relating to AUX Audio input, only one of them applies to an X150, the other does nothing in this car...
peterv8 (08-07-2020)
It’s always an adventure. I did speak to an Indy shop called Jaguar Specialties that’s 60 miles from me. He has SDD and knows what I need. Unfortunately, he’s all booked up for 3 weeks. The local JLR dealer called me back to say that they would try, but we’ve had severe thunderstorms and his SDD got a power surge so it isn’t working...
You are so right...they are clueless...one guy told me that my ‘09 XK might as well be 100 years old...they don’t want to work on them...
The instructions apply to the 4.2L engine not the 5.0 L engine. I am told by a Jaguar Dealer shop foreman that it is impossible to create am aux input on the 5.0 L cars. See below:
"That link is talking about enabling aux audio using SDD. That’s only available on SDD on 2007-9 XK. That option is not available on your 2013 XK because 2013 came with a USB and iPod port installed as standard equipment and its permanently enabled in the car’s CCF file. 2007-9 XK didn’t have USBs as standard equipment so Jaguar made an accessory kit to install one and created the software on SDD to enable it by modifying the CCF file. The option to enable aux audio isn’t available for a 2013 unfortunately."
I'm hoping somebody will be able to help me/us prove him wrong.
Cee Jay (08-08-2020)
If anyone needs the AUX enabled, I can rent my laptop and Mongoose cable to you guys in the continent of USA and will help you enable it under my supervision.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
