Hi i've problem on my Jaguar XKR 2007. I can't use SDD because it can't read my VIN number automatically and when i try manual VIN it say that VIN it's not correct. one month ago i use SDD and it's ok and now i can't use it. I've SDD 158 and VCM jaguar (Ford). The VCM is detect by pc.
The VCM have lignt on, but i don't understand what's the problem.
Is there possible have a problem on odb connector ? I try to use autoenginuity and it can't connect to my car.
Thank's for all.
Marc
Thank you for your answer. I don't know but i've control 12V on pin 16 and 4 or 5 and it's ok.
Today will control CAN BUS but i think it's ok because the car have no problem.
I go to control connector ODB. it's common problem ?
Marc
After control i've take tension values on CAN BUS, i've connect the cable on odb connector :
And i control on the connector VCM :
Low CAN/Ground = 2.15 V and High CAN/Ground = 2.70 V
I've control resistance between low and high CAN and i've 62 ohm.
These values are good for me.
I try to use ELM327 and it's impossible connect to ECU.
I don't understand what's the real problem.
Thank's
Other question : if i reset ECU can i have good connexion CAN after ?
Thank's
I've reset with battery negative cable on the battery postitive cable during 5 minutes.
I can read ECU with ELM327 and Torque on the phone but i can't connect VCM or autoenginuity.
I think that ELM327 don't have need protocol to access ECU but VCM or Autoenginuity read protocole and my car don't give the protocole.
Have you idea ?
Marc
Hi i've test my HS (high speed) CAN but i don't test the MS (middle speed) CAN on pin 3 and 11.
And i've the good tension (2.7V on MS CAN + and 2.18V on MS CAN -) BUT i have no resistor !!! i should have 60 ohm and i've infini resistor !!
On the wiring there are two resistors 120 ohm (one in the instrument group and one in the BRA (auxiliary)). I don't thing that the two resistors are OUT. What do you mind about this problem ?
If i've a pin deconnected on the ODB connector i don't have tension non ?
hi i've test MS CAN and it's ok. To have 60 ohms i need deconnect battery.
I've no pin déconnected on the OBD connector.
I don't understand why i can't read my VIN
I've try reset with battery negative on the battery positive and i wait 1/2 hour, wait and see !
Here pins VCM IDS Cable :
After reset with battery i've the same problem.
I've trying with IDS 118 on the xp virtuabox and i can have informations about DTC and all modules on my car !!
I don't understand why with SDD it's not possible.
Thank's for answer.
Yes i think it's a problem with new SDD (159) is not compatible with my old VCM. Before i used SDD 157 and i've no problem.
I've trying to reinstall SDD 157.
And yes i do to use IDS now .
