SDD Question: How do I check module for stored DTCs?
I got SDD up and running, but it's not the most user-friendly program and I'm confused about something. I'm getting a U0437-68. When I look that up in the service manual it says this:
So how do I check a specific module for stored DTCs in SDD?
Sam, it's referring to the DTC index in the service manual. For your issue, I think page 350
Download it here:
http://www.jagrepair.com/images/Auto...XKworkshop.pdf
You'll want to run a diagnostic scan and check against the DTC's on that page. That's my take on it anyway.
Download it here:
Thank you, Cambo! Your instructions were a big help! I forget the exact DTC #, but the description said something like "differential motor stuck". I'm paraphrasing, but it definitely used the word "stuck".
So... I guess the problem is the motor itself. I've been under the car to look at it. It looks like I might need to drop the whole rear end to get to the bolts on the top side of the differential motor.
STRrr
01-25-2013 03:16 AM
