Seat control module from another Jaguar?
Hello guys,
I have a problem with the driver seat. The recline function is not working. I have checked the buttons in the door and also the seat motors. Everything is working fine so I thought that the seat control module might be faulty.
I bought a used one from a Jaguar XF because the part number, sw version, hardware version (all the numbers) was the same as from my XKR.
Nothing works now, when I press forward the seat moves a bit and then it stops. Same for all the other seat control buttons.
Do I have to do some coding, is there a component protection on the seat control module or is there a teach-in required?
This was the auction:
https://www.ebay.de/itm/Steuergeraet...p2047675.l2557
Your module is fine, just needs to be reset. My son leaned mine back too far and mine did the same thing as yours. Had an indy reset it for me. Well damnitt if he didn't do it again the other day. Now I'm going to see if the SDD will reset the seat module. If so, I'm just going to buy that.
Chibbi (07-15-2020)
