Semi-active exhaust valve removal
Old 10-24-2020, 05:55 AM
Xk646's Avatar
Default Semi-active exhaust valve removal
Hello, is it possible to remove this semi-active valve, which means removing the spring to leave the valve always open and what would be the result?
The following 2 users liked this post by Xk646:
GGG (10-24-2020), Richardnero1 (07-26-2021)
Old 10-24-2020, 06:02 AM
jimbov8's Avatar
Have someone start the car from cold whilst you stand behind it and listen, if you can remove the spring then it will sound like that all the time.
Old 10-24-2020, 06:29 AM
Xk646's Avatar
For the mechanics or the loss of power that does not risk anything?
Old 10-24-2020, 07:27 AM
jahummer's Avatar
Received 2,380 Likes on 1,490 Posts
Or just pull fuse 19....
The following 3 users liked this post by jahummer:
guy (11-25-2023), ralphwg (10-24-2020), Stuart S (10-24-2020)
Old 10-24-2020, 07:31 AM
jimbov8's Avatar
The semi active system is not electrically controlled.
Old 10-24-2020, 07:56 AM
Xk646's Avatar
Yes I do this but blocked the springs in opening would do the same thing, right?
Old 10-24-2020, 10:19 AM
kj07xk's Avatar
Received 2,012 Likes on 1,345 Posts
Yes. Be interesting to see how you do it. I cheated and put an XKR back box on my XK, so the valves are normally open without the vacuum required to close them.
jimbov8 (10-24-2020)
Old 10-24-2020, 10:48 AM
Xk646's Avatar
Do I have to find a way to block the springs by cutting them out maybe?
Old 10-24-2020, 11:18 AM
Stuart S's Avatar
Received 6,320 Likes on 3,465 Posts
Why are you making more work for yourself than necessary doing something that is not easily reversible by the next owner? Keep it simple and remove fuse 19. It's really easy.
https://www.jaguarforums.com/forum/w...ad.php?t=87400
Old 10-24-2020, 11:29 AM
Xk646's Avatar
No fuse on the xk you confuse with xkr
Last edited by GGG; 10-24-2020 at 01:14 PM. Reason: Traduire la citation en Anglais
Cee Jay (10-24-2020), jimbov8 (10-24-2020)
Old 10-24-2020, 11:31 AM
jimbov8's Avatar
[QUOTE = Stuart S; 2307567] Pourquoi faites-vous plus de travail que nécessaire en faisant quelque chose qui n'est pas facilement réversible par le prochain propriétaire? Restez simple et retirez le fusible 19. C'est vraiment facile.
https://www.jaguarforums.com/forum/w...ad.php?t=87400 [/ QUOTE]
At least you understand.
Old 10-24-2020, 11:39 AM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
Some guys have used heavy gauge wire to tie back the valves. That way it's still revertible to stock.
MarkyUK (10-25-2020)
Old 10-24-2020, 11:54 AM
Xk646's Avatar
And does that change the behavior of the engine? Less torque for example? What are they really for? :confus:
Old 10-24-2020, 11:59 AM
jahummer's Avatar
[QUOTE = Stuart S; 2307567] Why are you making more work for yourself than necessary doing something that is not easily reversible by the next owner? Keep it simple and remove fuse 19. It's really easy.
Perhaps if you had clarified more than just saying you have a 2008 X150....most who ask this question have active valves exhaust which can be defeated by removing fuse 19....
Old 10-24-2020, 12:02 PM
Cee Jay's Avatar
Manually opening the valves instead of letting them open themselves by overcoming spring pressure with exhaust back pressure really only makes the exhaust tone more aggressive earlier.
It's all about the sound, mate.
Old 10-24-2020, 12:04 PM
jimbov8's Avatar
Where do you put this wire on a XK back box?
Old 10-24-2020, 12:11 PM
Xk646's Avatar
OK this is only for the sound it's okay because I don't want to change the behavior of the engine
Old 10-24-2020, 12:14 PM
Xk646's Avatar
All were in me question no spring in an xkr
Old 10-24-2020, 02:09 PM
Stuart S's Avatar
I may be mistaken but, as I recall, the active exhaust is closed at low engine speeds to increase backpressure, which maximizes low-end torque.
I've had Fuse 19 out for many years and have never felt that my XKR was lacking in low end torque. Whatever the loss may be, for me it's worth it to get the improved exhaust note.
Old 10-24-2020, 02:15 PM
Xk646's Avatar
That's what I wanted to have that changes the torque at low revs! OK
Quick Reply: Semi-active exhaust valve removal
