Semi-active exhaust valve removal
The following 2 users liked this post by Xk646:
GGG (10-24-2020),
Richardnero1 (07-26-2021)
Received 2,012 Likes
jimbov8 (10-24-2020)
Why are you making more work for yourself than necessary doing something that is not easily reversible by the next owner? Keep it simple and remove fuse 19. It's really easy.
https://www.jaguarforums.com/forum/w...ad.php?t=87400
Last edited by GGG; 10-24-2020 at 01:14 PM. Reason: Traduire la citation en Anglais
[QUOTE = Stuart S; 2307567] Pourquoi faites-vous plus de travail que nécessaire en faisant quelque chose qui n'est pas facilement réversible par le prochain propriétaire? Restez simple et retirez le fusible 19. C'est vraiment facile.
https://www.jaguarforums.com/forum/w...ad.php?t=87400 [/ QUOTE]
No fuse on the xk you confuse with xkr
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
MarkyUK (10-25-2020)
[QUOTE = Stuart S; 2307567] Why are you making more work for yourself than necessary doing something that is not easily reversible by the next owner? Keep it simple and remove fuse 19. It's really easy.
It's all about the sound, mate.
OK this is only for the sound it's okay because I don't want to change the behavior of the engine
I've had Fuse 19 out for many years and have never felt that my XKR was lacking in low end torque. Whatever the loss may be, for me it's worth it to get the improved exhaust note.
I may be mistaken but, as I recall, the active exhaust is closed at low engine speeds to increase backpressure, which maximizes low-end torque.
