Service Manual / Wiring diagrams?
Nobody has a manual? Ok, let's try it this way:
1) Navigation hack - I want to locate the speed sensor wire and interrupt it with a switch so that I can input stuff while the car is in motion. Has anyone ever tried this?
2) Hardwire radar detector - I want to hardwire a radar detector using a power source in the overhead console but want to know which wires are switched and which are not.
3) Power antenna - I want to add a switch so I can raise/lower the power antenna on demand. For now I have the fuse pulled so it doesn't go up at all.
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
OK...let's see
1. Navigation hack...not sure about this but alot of cars require a "gizmo" to override in motion (got no idea on circuitry...but am interested in a solution)...maybe someone here has more info...
2. Wiring diagram/service manual....I got a wiring manual (and it is a manual....it takes up a binder) through an outfit in England on eBay....search eBay and see if you can find...if not I'll look up who I got it from tomorrow (it is at work and i am at home). As far as the service manual goes it was not available when I was looking about a year ago (so I got what I could...ie wiring manual)...but things change so it might be available now...
I have a escort 9500ci (remote model) and cannot remember where it is wired in but I would suggest getting a VOM (volt ohm meter) and finding a switched 12v source and tagging that. Btw my radar gps antenna is in existing jaguar trunk antenna gps housing and the radar display in my rear view mirror...I am still recovering from all of that...
3. Switched antenna-not sure on this one...generally a ground wire that is switched through radio controls antenna...my xkr is an 08 and luckily extending antenna was discontinued (I hate to think how many of these fellers have been sacrificed to the car wash gods...)
Guy
Guy
Guest
Posts: n/a
Ok, I took a closer look at the subscriptions - for the DIY home mechanic, it's actually not too bad.
For a single year, single model (for the one-Jaguar household), a day is $14 and a week is $25. If you can get in and save or print the stuff you need, that's not a bad deal.
But if you need it, yearly access is $274.
jagent
09-07-2015 05:00 PM
