Sewing Machine Under The Hood
I just did my first DIY oil change. Bought a Harbor Freight oil extractor and it went like clock work! So easy, though I'll be running this change short at <7K because didn't have access to Jag spec oil. Will hit a dealer next time I'm near for 8qts of Castrol.
Prior to buttoning everything up, I did a start test to make sure all was fine and the oil level was ok in the end. I found that with the beutification cover off the engine is producing a "sewing machine" sound. It is very loud minus the cover but not so much when it is on.
Obviously, I'm concerned, as that type of sound is really out of the ordinary and an indication of a problem.
I'm thinking it might be an idler pulley bearing or a chain tensioner as it changes pitch and speed with the engine. I couldn't dig into it more as I was already late for a paint shop appointment get a couple touch up spots.
I expect it back in less than a week but was wondering if anyone else had experienced that sound on the 5L non-SC and knew what it might be? BTW I noticed the sound was there prior to the oil change as well.
Thanks for your thoughts. I plan to pick up a stethescope this week to try to isolate (left/right/front/back, ect).
Like Q&C the oil issue is alarming. I don't know what the PO had in it and though the dealership assured me that it had been properly serviced prior to purchsase. A Car Fax check showed little actual Jaguar records which should have set off alarm bells on my part.
If it is oil related it should make for a good forum thread to warn others to be careful of oil service.
My first thoughts went to idlers, tensioners, water pump, etc. VVT and DI should be very easy to determine with the scope I would hope.
I'll have to try to find a schematic breakdown on the engine to try to visualize what might be going on inside though.
As Jagtoes suggests, "Don't overthink this".
Yup, agree with everyone so far. At this point it could be anything and I'll try to post an audio clip when it comes back from paint touch up. Short of anyone else experiencing the exact same thing, more data is needed to troubleshoot with any accuracy. Maybe that is what should be asked, has anyone else ever heard something similar with their own AJ V8 Gen iii? With the cover removed it is very noticable.
It runs smoothly and my incination leans toward it may be a characteristic and not unusual at all. The beatification cover is heavily insulated and the sound is hard to hear with it on. That said though, as are most of us, I'm not used to hearing this type of sound from a smooth running engine.
Received 2,263 Likes
That's the sole reason engines have these covers, or alternatively under hood insulation blankets. Nothing to do with either beauty or 'beatification'.
Ok, she is back from the paint shop so I've attached an audio clip of the sound. This is with the engine cover removed.
I used a scope on it and found that it is loudest on the fuel rail so it appears it is the injectors that I'm hearing. I think I worry too much and need to just enjoy the car!
I will be changing oil again as discussed though. I found a dealership in Memphis that sold me enough for the next two changes. I found it funny how the prices within the state of TN were so widely different. From $9.95/qt to almost $14.00 at dealers in Memphis, Nashville, and Chattanooga.
Thanks to everyone who engaged in helping me with my needless worry.
![Icon Screwy](https://www.jaguarforums.com/forum/images/smilies/icon_screwy.gif)
It doesnt sound right to me, and it doesnt sound wrong either.
You nailed it that it sounds like a singer.
How did you record that sound and at what location, I will try to replicate it although I have a different car.
Where did you find it for $10 a quart- I understand if you want to guard your well.
I used my cell held at about 3" above the intake at the front of the engine. The fuel rail crossover is right there so when I put my scope on it the sound really popped up......almost too loud to stand, even with my bad hearing.
I got it at Bluff City Jaguar. Parts man said they had just got a shippment in but it totalled only about 4 cases. That was last weekend. He told me they have a hard time getting 0w-20 in consistantly. That is why I decided to get two changes worth.
