Should I buy this XKR?
I can pick it up for $23k. It has 109k miles but its a 1-owner car with a flawless carfax maintenance history. Should I go for it or is a ticking time bomb after 100k miles?
Any advice would be appreciated.
2007 Jaguar XKR, $25,991 - Cars.com
Have a thorough inspection by another Jaguar dealership going through all the major systems. Yes, the price is low, but it's a Jaguar with a high clock and repairs at this age and mileage can be excessive and quickly add up. Yes, it's a plus with all the service history. If the body and interior are clean with no paint/accident history, at that price you probably will not get hurt and will probably be able to flip it again if it doesn't work out to someone who wants to step into XK ownership.
Received 1,103 Likes
seems fairly priced to me.
Bushings may be needed, brakes, belts, fluid changes, filters... but the engine should be solid for another 150K. At least that's my expectation.
I smirk when I hear others complain about dependability and heightened maintenance as that's not my experience at all... and I have had a few.
Good advice already on checking service history and expectation of item requiring attention.
I can't comment on the price as values this side of the Atlantic are very different but the phrase in the Ad that caught my attention was:
....BOUGHT HERE NEW...ALL SERVICE WITH OUR DEALERSHIP...
If the dealer had any doubts, they would have moved it on through the trade. Reputation counts for a lot in the used car business regardless of where in the World you happen to be.
I hope it checks out OK but if not, walk away because there's always another out there.
Khan (09-19-2013)
Yes! If all I had was $26k Heck yes!....This car is from a rich area in Marin County San Francisco Bay Area and it's all freeway around there with long commutes, so 109k miles is not that hard on the car, plus it's had all of it's services and pampered it looks like. I cant find any wear in the interior. It's from the Dealer so he's not gonna sell junk to get him in trouble like GGG said, he would just wholesale it to an auction house. Must be a clean car. I'd be surprised that the car was still available. Stop reading this and call and put a deposit on it NOW! Then have it checked out by another dealership. but at least its held for you.
I own a 2007 and it's been the most reliable car I've ever owned. Go for it....I would!
The Carfax on this car looks very good with regular maintenence by a Jaguar dealer. I can't see anything wrong and absolutely no evidence that there is water damage or salvage.
Here's the link to the Carfax.
Others here on this forum can provide an opinion after reviewing the data via this link.
Check it out. To me car looks normal with average mileage for a 2007 and as one other poster here stated, the car comes from an exclusive area of Northern California.
CARFAX Vehicle History Report for this 2007 JAGUAR XKR
Here's some additional information on this car:
Year 2007 Engine Type 4.2L V8 DOHC 32V SUPERCHARGED
Make Jaguar Driveline RWD
Model XK-Series Ground Clearance 3.90 in.
Trim Level XKR Coupe Front Brake Type Disc
Manufactured In UNITED KINGDOM Rear Brake Type Disc
Body Style COUPE 2-DR Anti-Brake System 4-Wheel ABS
Transmission 6-Speed Automatic Overdrive
Standard Seating 4
MPG Hwy 25 miles/gallon Optional Seating No data
MPG City 17 miles/gallon Tires 245/40R19
Dealer Invoice $78,110 USD Wheelbase 108.30 in.
MSRP $85,835 USD Curb Weight 3814 lbs
Standard Seating 4
JimC64 (09-19-2013)
All of the interior should be leather, which includes seats, dash, door panels.
Only hard thing to clean is the inside roof interior material, try Fabreeze.
When buying, try to stay within these pricing guidelines:
Looks like my offer would be: $23,000 to $23,500
I'd also recommend replacing the transmission pan-fluid. Costs about $500 at an indy dealer.
If this car wasn't solid, they'd wholesale it out and be done with it.
I wouldn't worry about the miles on the clock either. Mine has done 160,000 plus K's and still feels like new. Basically if it is regularly serviced then all should be good. Check that the spark plugs have been changed. The transmission fluid and filter. (They change the whole trans pan as the filter is fixed.) Also the belts should be changed. As for electrical problems. Only issue I had was down to the famous battery problem. I replaced mine with a AGM battery and no more issues.
As long as you get a good inspection done and you take it for a long test drive. You should be fine.
Good luck with your decision.
No, but a lot of the information from there can be verified because their uncle lives next door to a guy who used to work with a guy who was married to a woman who's dad used to have one.
