Should oil change only be done by dealer?
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/716x893/screenshot_20220406_033306_chrome_ce2c7ba8d6aa39cb9dfe8a96b47f8c9dfe8d02cd.jpg)
This thread is now an annoying waste of my time. Since it hasn't been closed, I unsubscribed from this thread.
The following 3 users liked this post by No Quarter:
Sean W (04-06-2022)
The spec change you posted does not apply to 4.2 engine.
Unless i'm missing something here?
RichardS (04-06-2022)
Since this is an oil thread: now that I've got the sportbrake, does the XF 3.0 take the same filter as the 5.0? I got one of those blauparts oil change kits for the XKR (8 liters of Ravenol 0-20 plus a filter) about five days before I lost the car, and oil change time for the sportbrake is coming up...
#28
Hhmm, just remembered something, wasn't quite sure, had to go check. Yes, on the oil filler cap it says 5W-30. That's a pretty strong hint as to what should be used, not?![Icon Rolleyes](https://www.jaguarforums.com/forum/images/smilies/icon_rolleyes.gif)
Don't use the oil the ads lead you to, don't use the oil friends "have used for years without problems", don't ask a seller at the parts store. No, look in engine room/user manual/service manual what the builder of the engine recommends, and use that!
jahummer (04-06-2022)
To answer the OP's question as others have, I used the main dealer for many years because the price they charged me was unbeatable, even via DIY and then there were the associated perks. But, that's changed with massive price increases and it's now significantly less costly and more convenient to do it myself. In my garage it takes about 15 minutes for any of the vehicles and about $50-$60 in materials using OEM filters and proper spec oils.
steve_k_xk (04-06-2022)
#30
Now BMW says the V8 and V10 rod bearing needs to be replace at 100k km as part of schedule maintenance. Ouch!!
#32
Yes, the 3 litre's the same spec. And for clarification, it's the second number that matters the most, the difference of 0W vs 5W relates to climate, colder climes use 0W, warmer temperate use 5W though the difference is minor. Main dealers in my region still use 5W20 for the 3 and 5 litres and 5W30 for the 4.2. Higher viscosity such as 40 or 60 should be reserved exclusively for the track where the engine's run at high RPMs for extended periods of time and need the extra protection from the extreme heat. You'll never find that in daily driving where the lower viscosity's required to protect the engine in normal road use.
OH, AND... for whoever's still reading, I bought an oil exctractor, and the XKR oil change was, and still is, the easiest oil change I've ever done in my life.
And there's an extractor suction tube in the XF, so....
#33
Wow a 10w-60 oil viscosity. BMW high revving E92 V8 and V10 has rod bearing issues / failure because they run the same 10w-60 high viscosity oil and owners revs the hell out of the motor before the motor comes to temperature.
#34
Received 3,209 Likes
For example see the Rock Auto page here: https://www.rockauto.com/en/catalog/...il+filter,5340
Best bet on that page is the Wix 57279, a top quality filter at a bargain price.
pk4144 (04-08-2022)
#35
At 100k km bearings, looks ready to spun and or lunch the motor real soon.
![](https://www.langracing.com/wp-content/uploads/RodBearingS65.jpeg)
steve_k_xk (04-08-2022)
#36
At engine startup you want the thinnest viscosity oil as possible, ie 0w or 5w so the oil can flow as FAST as possible to protect the top of the engine critical parts such as cams etc.
Once the engine (not the coolant) is at OPERATING TEMPERATURE it does not matter what the ambient outside temperature. You could be in the freezing subzero snow then drive into the hot 60C desert and then back to snow again in the same day. Are you going to stop on the side of the road and do an oil change because the outside ambient temperature changed from -10c to +60c?
Its up to the cooling system, ie radiator and thermostat to maintain the engine at range of 95-110degC no matter what the outside ambient temperature is. A higher viscosity oil just makes the engine run hotter as it flows slower than a lower viscosity oil. Too high of a viscosity and you risk lunching the motor or a piston through the block.
Modern engines has very tight tolerances and the function of engine oil is to not only lubricate metal to metal parts from touching also for cooling / transfer of heat. Oil is used to remove and cool down engine parts such as the bottom of the pistons. Using a too high of a viscosity you are slowing down the cooling effects of oil to the pistons.
Sorry I deviated from the original post. I'll shut up now.
#37
From the XK 4.2 manual:
For climates ranging from -35°C to +50°C (-31°F to +122°F), the following oil viscosities may be used:
0W-30 protects from -35°C to +35°C (-31°F to +95°F).
5W-30 protects from -30°C to +35°C (-22°F to +95°F).
0W-40 protects from -35°C to +50°C (-31°F to +122°F).
5W-40 protects from -30°C to +50°C (-22°F to +122°F).
All these viscosities would be fine for the UK. As I said above, it's really not that important.![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
Richard
Richard
kj07xk (04-07-2022)
#38
Received 1,975 Likes
Richard
Richard
#39
#40
Having had a few BMWs (2 e38s and an e83), they seem to unofficially expect you replace the whole damn cooling system, whole emissions system and such at periodic intervals. What's rod bearings every 60k between friends. Keep in mind I hate the ZF 5HP24 transmission and even they go more than 60k miles between major work.
For the Jaguars I run Mobil 1 or Castrol Synthetic or Pennzoil Platinum, whatever in 5W30 and change every 3-5k or once/twice a year. I run good filters too like Wix/NAPA Gold. I change the SC oil with the GM stuff every 30k. PS/Coolant/Brake Fluids every 2-3 years. Transmission and differential oil every 30-45k. Air filters every 12-24k depending on recommendation. Fuel filters in gas cars every 30-45k, diesel fuel filters every 15k. Do this in all my cars (except PS in the VW since electric PS, but otherwise same). Longevity is more a function of frequency and regularity of the change of fluids and filters than the quality of the fluid, as long as it meets the specification and is of at least average quality. I do run the overpriced 5W40 Ferrari/Maserati Pennzoil Platinum thats $90 each change and their overpriced filter at $30 but it matters when you resell more than OEM only on a Jaguar.
Pay attention to your cars. Fix it when lights come on. Fix noises and smells. Replace belts that have weather checking or squeal. Check tires and fluids (that you can reach) when at the gas station getting fuel. You can check oil, PS fluid, see the level for the coolant overflow tank, eyeball the engine for leaks and see if the tires look off in terms of alignment or air pressure (and you have TPMS but still) while its filling up fairly easily.
