Side Marker Eliminated.....GOOD/Aston Martin Grill on a XKR.....BAAD!
So I came across this pic and notice they eliminated the amber side marker inside the headlight. I know some people were trying to figure out how to remove it. Then I noticed the aston martin grill. Nothing wrong with the AM grill as I think it looks good but not on a Jag!
Anyways....I emailed them to see how they removed the amber sidemarker inside the headlight.....hopefully they will reply back.
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
![](http://www.priordesignna.com/JaguarXKRBlack_0000_1.jpg)
Received 2,190 Likes
Looks to me they have seperated the glass/plastic, as it looks like they have also painted the bezel and chrome effect inside the lamp..... I quite like that, stealth look which works well on a black XK
Have to agree about the front grill always a bad move when you take such a distinct characteristic such as the AM grill and put it on a completely different car, something I would never do!
That is one sweet looking vehicle, and I think the AM grill looks very stunning.
As for the headlamps:
Remove the headlamp assembly from the vehicle, remove all rubber and light bulbs from unit, place in oven set at 200 degrees for 8 minutes, using oven mitts remove, begin prying where the clear lens meets the black casing, put back in oven for 4/5 minutes repeat until you are able to seperate into 2 pieces.
The oven loosens the sealant very nicely.
Brutal....definitely Jaguar should offer an optional manual eventhough these days car makers are moving towards DCT/SCT over manual.
So I didn't get an reply email from them regarding how to remove the sidemarker. Looking at pics when I remove the headlights in the past....it looks like there are clips to hold the clear lense ot the headlight unit. Most likely if I remove the clips......the clear lense will pop out from the unit. I'll have to check it out when I remove the headlights next time. Thanks guys for the info!![Cool](https://www.jaguarforums.com/forum/images/smilies/cool.gif)
![Name: clips.jpg
Size: 54.8 KB](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/170939d1501285260-side-marker-eliminated-good-aston-martin-grill-xkr-baad-clips.jpg)
![Name: clips.jpg
![Name: clips2.jpg
Size: 35.3 KB](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/170940d1501285260-side-marker-eliminated-good-aston-martin-grill-xkr-baad-clips2.jpg)
The clear lens will not "pop" off when clips are removed, the clips were installed to hold assembly together while adhesive cured. I have cut the seam on Viper and Ferrari to refinish the interior then glue back - have not tried on Jag yet, but I am considering a project on my XKR Portfolio, If I do will upload photos
I can definately confirm the clips do nothing apart from what Jeffrey has said, I did look myself some time ago as I was asked to make some new bezels up with LEDs in them for a DRL, I did a very similar thing on a DB9. The XK plastic cover is glued on well, the oven idea would be a good one, just don't over cook it ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
![Name: KDB20.jpg
Size: 63.1 KB](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/170428d1501284306-side-marker-eliminated-good-aston-martin-grill-xkr-baad-kdb20.jpg)
If you can get one apart and send the bezel to me, I could do it no probs.
I do not have any X150 light units hanging around here to try it on
doctordeuce
09-12-2015 08:30 AM
1964Daimler
09-09-2015 11:28 AM
