Side Marker Removal
Hey Mike......not sure if this pic will help as the hole is actually where the bulb socket sits as the housing is over that. I removed the louvers before but forgot how the side marker housing detaches. I have the housing somewhere in the storage but I tried to look for it but couldn't find it.
Maybe use a small flathead screwdriver (of course use a cloth in between) and gently pry it towards the rear of the vehicle (according to the manual). Just a thought.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
BTW.....or get the '10 louvers for a cleaner look.![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
![](http://i257.photobucket.com/albums/hh211/lionheadxkr08/lh1.jpg)
Thanks Ghostrider... got it off with just a small chip on the housing (oops) luckily it's on the part in your pick so the housing hides it.
I did this to test if I swapped side marker bulbs would the "indicator lamp failure" jump to the other side as well.... It didn't
I'm going to test the ground wires next and possibly re-wire the tail lamp ground, this worked for some BMW owners.
Any luck with your brake lamp?
aholbro1
08-05-2021 05:02 AM
