Simple A/C Condenser Drain Fix
After noticing the dreaded condensate water in the passenger footwell of my '07 XKR (14k miles) from clogged A/C drain tube, I diligently checked the forum and found that I needed to: either drop the tranny and update the A/C drain hose; remove some exhaust parts and cut off the end of the drain hose; or add a new DIY drain hose behind the carpet in the passenger footwell. OK, says I: put in the DIY drain and that way, you can access and clean it easier if it clogs again.
So, looking in to the footwell with carpet removed, I see the little triangular funnel on top of the drain tube over the tranny in the center of the dash. See the low, black piece in left center of pic. Hmm. Maybe if I whacked it ( I used a 12" x 1/2" steel rod) it might loosen up the tube and start draining. I really didn't want to drill holes in my mint XKR floorboards. Sure enough, a couple whacks resulted in a fine half pint of drainage onto the garage floor. Problem solved, at least for now, and all it takes is pulling back the carpet and whacking the tube a couple times. Less than 10min work. It's been draining fine for over a week now.
The following 17 users liked this post by hloucks:
amcdonal86 (06-10-2015),
bgpenguin21 (07-24-2023),
Big Otter (06-15-2015),
bobdr1 (01-29-2015),
Chaos236 (06-14-2015),
and 12 others liked this post.
powerhouse (01-29-2015)
The only thing i see in your picture that looks like a pipe is where i have the arrow pointing to. Is this it.
The following 5 users liked this post by Cee Jay:
powerhouse (01-29-2015),
Redline (08-02-2021),
Stuart S (01-28-2015)
So far I don't have this problem and hopefully it has been corrected in MY. I was thinking though why not become an auto surgeon. If you look at how orthoscopic surgery is done why not use a bore scope to find the duckbill and one of those remote pick tools to squeeze it open. Don't know if it would work but I would bet at least you can see the problem with the bore scope. My 2 cents here.
The following 3 users liked this post by DpezXK8:
Hloucks, you say "I see the little triangular funnel on top of the drain tube over the tranny in the center of the dash", can you see the drain tube itself.
So now we have 3 different ideas of where the drain pipe might be, if this a quick and easy solution is would be great. Could make up an air hose connection to give it a good blow now and again. Has anyone had a look at theirs yet.
Quick A/C Drain Fix Whack Area
Sorry guys, I should have been more clear regarding the area. Yes, DpezXK8 circled the correct area for the drain in red. The black plastic condenser housing has a little triangular shaped "funnel" over the center of the tranny tunnel that has the drain tube attached to the bottom. You can't see the drain tube from the passenger foot well, but you can easily see the funnel and get to it for a little whacking. I wouldn't recommend hitting it too hard as I guess it could break. I hit it 5 or 6 times about as hard as I would hit a finish nail in carpentry. The car is still draining properly now after a couple weeks.
Good luck,
Harve
Good luck,
Harve
Good luck,
Harve
Good luck,
Harve
Who's going to be the first to operate, if the hose is just behind this area, what a save of time and money, go on someone give it a try and pics.
FrickenJag (06-11-2015)
Received 1,177 Likes
So this is the funnel where the water gathers and then goes out through the drain tube. What about if a small hole was put in this funnel, would water come out, or a hole the size of a small cleaning wire (coat hanger) put in to clean the tube. A air hose on/off connection could be another option, for blowing it out, wonder would it work. The previous owner had the fix done as i have the receipts, so hopefully it wont happen again.
The following 2 users liked this post by GovtSlug:
GovtSlug --- glad the A/C drain "whacking" worked for you. My drain seems to be still working now 5 months after whacking. I'm keeping an eye on it, but no water in the passenger foot well yet, even with long trips in hot, humid weather. I'm still inclined to remove a section of exhaust, and cut off the end of the tube the next time I have the car up on jack stands. Good luck,
Harve Loucks
Harve Loucks
Well, I gave it a try. Pulled carpet back and gave this plastic area a little knock or two with a long bar, and I started noticing drips under the car. Drove around for an hour or so in 95 deg and no drips inside. Seems this works. Well played guys. Thanks.
