Simple TPMS question
Old 04-20-2018, 08:22 AM
10XKR's Avatar
Originally Posted by richzak
The cost to replace all 4 is about $200. The Jag XK/XKR will read the new TPMS and automatically reset after 5 to 10 minutes of driving.
I went thru the same problem on my 2009 XKR and after many frustrating months of warnings, replacing the 4 sensors fixed the problem immediately.
Where is the best place to get the sensors, especially at that price.
Thanks in advance,
Dave
Old 04-20-2018, 09:14 AM
Sean W's Avatar
Received 4,232 Likes on 2,373 Posts
I dunno about $200 but this is close.
Amazon Amazon
My local tire shop replaced them for $10/ wheel.
There are less expensive sensors than the VDO brand, but you won't find better reviews on them.
10XKR (04-20-2018)
Old 04-20-2018, 09:26 AM
10XKR's Avatar
Hi Sean,
Thank you sir!
Cheers,
Dave
Old 04-20-2018, 09:45 AM
Cee Jay's Avatar
Received 5,391 Likes on 3,189 Posts
Originally Posted by Sean W
My local tire shop replaced them for $10/ wheel. ...................
You sure about that??? Most tire shops include what they call "TPMS REBUILD" which is a fancy way to say New Core and New Cap for the old one.
Old 04-20-2018, 10:17 AM
Originally Posted by Someb
I had the same problem. The dealer installed an upgrade of the TPMS-software/system; so far so good.
Grtz
Ben
I think this might be the answer. Mine dances around from time to time, bouncing between all 4 tires. Too rare to predict, too frequent to dismiss. I believe I replaced all my TPMS sensors when I got new tires about 3 years ago. Of course the problem didn't start until after that, so, who knows. Please post up if your problem returns.
Old 04-20-2018, 02:19 PM
Sean W's Avatar
I replaced them last season. I bought them off Amazon, they charged me $10 per tire to install them. They showed me the serial numbers from their reader. Matched my paperwork. What am I missing?
Old 04-20-2018, 03:55 PM
Cee Jay's Avatar
AAHHHHHHHHHH....... $10 to INSTALL ones you had already bought. I get it now. I thought you had said the tire place installed new ones that they had, all for $10.
My bad. Disregard.
Sean W (04-20-2018)
  #28
Old 04-20-2018, 06:54 PM
Stuart S's Avatar
Received 6,295 Likes on 3,455 Posts
Ambiguity causes confusion and contusions. My favorite example is "John mopped the floor with Fred." Here's Fred, but his contusions aren't visible.
The following 2 users liked this post by Stuart S:
Cee Jay (04-20-2018), ralphwg (04-21-2018)
Old 04-20-2018, 08:01 PM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
I always liked the song " she had freckles on her but she was nice". I forgot where the comma goes.
  #30
Old 04-20-2018, 08:18 PM
Cee Jay's Avatar
There's another one..... "I wanna kiss her but she won't let me".
  #31
Old 01-20-2019, 01:53 PM
rickkym's Avatar
2007 xkr and I just had all four tires replaced and now the TPMS fault flitters around and then disappears. I had the sensors 'checked' before I did the tires and the diagnostic tool said the batteries were good. I've tried the 40+ pounds of air trick, I took out the tpms fuse and danced about the car, I may try nitrogen. But the deal is the sensors send out a fairly complex digital signal (at 315mhz) that has the pressure and lots of data encoded in it. So either the batteries are strong enough to send this signal or they aren't. And if the car can't see all four sensors and read the signal you get a 'sensor' error on the dash not a low tire warning. So if you don't see the sensor warning on the dash your sensor batteries are fine.
According to Jaguar of Tacoma it's the TPMS module in the trunk. A re-flash may fix it, but probably it needs replaced. And it's just a dang-odd thing it acted up RIGHT AFTER I had four tires put on.
  #32
Old 01-20-2019, 02:13 PM
jagtoes's Avatar
I purchased a TPMS sensor reader and from what I see it will read , serial /part number , location , battery condition , tire pressure and tire temperature. It works for both 315mz and 415 mz . It also plugs into the OBDII port and will change , add or move sensors on all 4 corners. I can also buy $28 sensors and reprogram them or clone the OEM ones. And last it allows me to turn off the TPMS light on the dash . Most tire dealers want to do the $10 rebuild which is a new o-ring and stem valve insert. They will replace them but sometime won't turn off the light. Some cars require it and others will read the replacement sensors.
  #33
Old 01-20-2019, 04:54 PM
kj07xk's Avatar
Received 1,996 Likes on 1,335 Posts
Hmmm... makes you wonder if maybe they damaged one or more of the units while replacing the tires...
  #34
Old 01-21-2019, 09:17 AM
richzak's Avatar
Received 1,233 Likes on 789 Posts
End the frustration. Replace the TPMS. Your Jaguar XK/XKR is a 2007 and probably produced in 2006. Look at the door panel, it will provide a date of manufacturer. The TPMS has built-in non-replaceable batteries that last 7-9 years.
The life of your sensors are nearing their end of battery life.
Once a TPMS goes bad, the battery is not replaceable and the entire sensor needs to be replaced.
You will spend more time trying to diagnose the problem with lots of frustration in between. Your car is a 2007, probably built in 2006. (Look at the door panel for date of build).
Bite the bullet -----REPLACE all sensors. Buy the good ones ---SIEMENS.
__________________
  #35
Old 01-21-2019, 10:10 AM
Stuart S's Avatar
Hi Richard,
Good advice! Glad to see that you're still lurking around here! Time for the F-type SVR?
Best regards,
Stuart
  #36
Old 01-22-2019, 09:10 AM
richzak's Avatar
Stuart:
I am looking. The aftermarket for the Jaguar brand is virtually non-existent. I am seeing 2014 XKR's for sale with ultra low mileage in the 25M range, which is unbelievable to me. There is just a very poor aftermarket for the brand.
I have read where Jaguar sales are extremely poor, especially in the sedans XF, XE etc.
  #37
Old 01-22-2019, 09:24 AM
Stuart S's Avatar
Yes, it's a buyer's market - and that's great if you're a buyer! Demographics have changed, and practicality rules. SUVs are King, and sedans are a dying breed. Cars like the XK are non-essential playthings for those who already have an SUV. Also, depending on where you live, intimidation by political correctness is a factor - witness the growth of EVs.
  #38
Old 01-22-2019, 09:38 AM
shemp's Avatar
Hey, richzak is back!
TMPS.... On my 2010, it seems whenever one or more of the tires gets low, the whole system goes bonkers. I went thru this last year (documented in a thread somewhere...), did the 40lb trick for 1 week and it worked. Ok now for about a year. Just recently I had a screw removed in a tire and whatever the tire place did triggered the Christmas light show. All tires were at 33lbs. I raised the pressure to 35 this time and it's fine again. For now.
I assume my TMPS transmitters are at the end of life but struggling to hang on. I'm hoping they will last until the next tire change (1-2 years). If not, I'll get them replaced like richzak recommends because that TMPS warning on the message center (the car graphic, not just the yellow triangle) is annoying.
So, to rickkym, If you can, drive around for a week or so with the tire pressure at 35-40 (you said you tried the 40lbs trick but didn't say for how long) . See what happens. Maybe the system will settle. If so, drop back down to 33lbs. If it doesn't fix it, no harm done.
  #39
Old 01-22-2019, 09:54 AM
jagtoes's Avatar
It's pretty simple to just go to the nearest tire dealer and have them do a sensor test. Takes about a minute or two. They can give you the sensor battery status. It would either be good or low or bad. A low battery will be intermittent and will at times trigger the system. Usually when just starting the car and when the tires are cold even if the pressure is correct. Also sometimes the sensor will read OK as the tire starts to heat up. If the batteries read good and the sensor triggers then you may have other problems. Just my 2 cents
shemp (01-22-2019)
  #40
Old 02-02-2019, 07:44 AM
chazaroo's Avatar
__________________
Just curious, why Siemens?
Quick Reply: Simple TPMS question
