Slight gap in soft top
Hi all
I’m a first time Jag owner having picked up my 2007 XKR Convertible a couple of weeks ago and love it. I had the roof down last weekend because, well, it wasn’t raining for once. However since then, the bits of the soft top just behind the windows isn’t quite going down as far as it should, leaving a very slight gap. It’s tricky to explain so uploaded a couple of photos. Has anyone had this issue before and managed to work out what was causing it?
Thanks in advance.
Thanks in advance.
What in hindsight I haven’t captured well in my photos is it’s letting in a decent amount of light and the road noise is much more noticeable than it was because of that. It’s not letting in any water which is a relief but the roof should definitely be going down a couple of cm more than it is imo.
That's not the roof though, it's just the flimsy interior lining. The actual roof is down solidly all the way around. I suppose there IS a way to maybe stretch the liner down a bit more, but I've never noticed mine like that so I won't ever notice it again. Plus, my entire roof is down nearly every time I drive.
ralphwg (03-17-2024)
I’ve taken another photo showing the gap and the bit of the outside you can see at the right angle.
