Slow coolant leak
Hello Everyone:
I have a very slow coolant leak. I had my xk jag parked for maybe a month in my garage. I went out and drove it around and the low coolant light came on. I drove it home, coolant overflow was almost dry and added half a gallon of antifreeze to fill up the coolant overflow. I have been watching the level on a daily basis. The coolant overflow goes down maybe 1/8 - 1/4 inch daily without driving the car. Has anyone ever had this happen to you? How would I check for coolant leaks? Do I add pressure to the radiator or coolant system and look for leaks? Any help? Thanks .
You can't access the radiator directly but you can use a pressure tester on the expansion tank to apply pressure. With that amount of coolant loss, especially when the engine is cold, I'm surprised that you don't find a puddle on the garage floor which would enable you to find out where the leak is. Remove the undertrays to see if there is any coolant collecting on top of them.
Is there any sign of emulsion when you remove the oil filler cap? I don't think you have a dipstick so it's more difficult to check directly whether there is any water in the oil.
Richard
Richard
If the coolant loss is definitely not found under the car or in the V between the cylinder banks, and even here it will eventually build up and find its way onto the floor, then it can only be leaking into the cabin area from the heater matrix or into the cylinders from the head gasket. If the footwell carpets are dry (and you will usually smell coolant in the cabin) and there is no white emulsion under the oil filler cap and the oil level is not rising in the sump and there is no excessive steam in the exhaust, then the leaking coolant from a cold engine must eventually appear on the floor. Pressurising the system with a test kit should expedite matters.
Received 1,122 Likes
guy (10-25-2023)
OP, I would grab a flash light and look behind the engine to the top of the trans bell housing for coolant residue. If you see residue, its the rear crossover pipe, fairly easy/cheap job. Thats where my wifes XK and my 2016 Range Rover was leaking from.
If no bueno, add some coolant UV dye and a pressure tester.
silversurfer1221
10-30-2023 10:15 PM
