The small pully that could
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
This is in part a long overdue shutout and thanks to Brutal. Recently my 07 XKR provided me a reason to remove the supercharger, a leak in a cooling hose that can only be changed by removal of the supercharger. Brutal suggested 'hey if it has to come off, why not change your pully'
So it was done. A local shop that Brutal knew reduced the snout to receive the Eurotoys 2.5-3lb pulleyl for a reasonable fee. When I got the car back Brutal said, you will notice it comes 'on' sooner... And that it does.
I have the Nameless high-flow cats, otherwise stock. The throttle is much crisper and responsive, power comes on fast and stays strong to redline. I was skeptical but the upgrade was really worth the cost.
Best way to describe it is.. You know how frisky the car is on a 'cool' day, it is like that all the time now.
Thanks Brutal
Thanks Brutal
Does anyone know if this can this be done to the 10+ XKR's? Or has the pulley already been resized/maximized on the 5L's?
Edit:
Yes it can:
http://www.minagallery.com/jagxp/Jag...c%20pulley.htm
How many of you with 5L's have done this?
Edit:
Yes it can:
Hey Gn4hir, I just had mine done too, I feel the same results as you but I was wondering did you do a ecu clear? (battery disconnect)
If you did, how long of a learning period did you give it before really stepping on it?
I'm taking it easy for 200 miles for the air/fuel to re-adjust and I hear it just gets better as the ECU adjusts.
It does not effect me as the owner of a regular XK but, just wondering how the pulley change actually works for the supercharged cars?
I recognize that a larger pulley would spin the charger faster, thus increasing boost. But, boost is normally controlled by some kind of overboost protection device (spring loaded or electronic) that opens when the set boost value is reached, dumping excessive boost. If it did not work this way, than the boost would greatly vary between low RPMs and high RPMs. So, I would think that installing a larger pulley would have to be accompanied by some kind of change to the boost control systems if an increased level of boost is desired..
Albert
Albert
I guess I have some research to do on ECU programming.
Albert
Albert
I don't think it builds pressure that has to be bled off as it always turns in direct ratio to engine rpm, it can't spin up like a turbo does.
200 yds or 20 seconds.. whichever occurred first. Actually, I didn't know I was supposed to reset the ECU. It is possible the guy helping with this did that for me.. but I did not. And I would not say I drove any different that I normally drive which is fairly aggressive..
I believe regardless of "clearing" or not the ECU will re-learn continuously as the car is driven. I figured it wouldn't hurt to take it easy at first but I've gotten tired of driving soft. Time to step on it and enjoy the bigger power band
Thank you and enjoy!
