Smell antifreeze in exhaust
How is the level in the coolant tank. Also what is the level of the oil on the e-dipstick. Is it over full. Some white smoke is normal during start/warm up . What about your water temp. after warmed up. Head gaskets just don't normally go bad unless you overheated the engine. The smell can be from a leak somewhere other that a head gasket. Don't over think the concern.
badicedog (07-17-2019)
Also, if that goofy plastic coolant manifold on the firewall leaks it'll most likely drip on the cats. Chances are something could be seeping and you are noticing it upon startup. White exhaust could be condensation with a little stink mixed in. Monitor the coolant level to get an idea of your loss.
Hey what was the verdict? I’m interested….. don’t leave us hanging you can help another member out with the solution.
The following 3 users liked this post by The_Ikon:
