Smoke comes out the rear at WOT at high RPM
Have you ever noticed a lot of smoke coming out the tailpipes if you're really accelerating hard at high (5500+) RPM? I seem to notice quite a cloud of smoke being left behind by the XKR, especially during the 1-2 or 2-3 shift (I don't think I've ever done a WOT 3-4 shift) where there's a bit of RPM overrun and a little bit of a backfire.
Is this normal? It looks and sounds sweet when it does it, but I wonder if it's a sign of abnormal engine wear or not.
As you surmised, your probably running a tad rich. This could be by design, as "too rich" is far safer on an engine than "too lean".
Don't know the XK well enough to speak of first hand knowledge, but the last car I owned that did this had a bad O2 sensor. The cars ECU "fail-safe" was to run rich to prevent engine damage.
Vince
Vince
I suppose a sensor could be riding the edge of the tolerances allowed? MAS (Mass Airflow Sensor) could be dirty as well.
When's the last time you ran a proper fuel cleaner through the system or changed the air filters?
Just thinkin "running rich" thoughts out loud...
Vince
BTW.
Terminology we all grew up with can be misleading. We use the word backfire for any bang outside the combustion chamber.
"Backfire" actually refers to a combustion process that occurs in the intake runners before the combustion chamber. It is most often related to valve timing issues, or an overly lean mixture.
"Afterfire" refers to a combustion process that occurs in the exhaust system, after the combustion chamber. Often related to rich mixture.
Just an FYI
Just an FYI
The following 2 users liked this post by CleverName:
amcdonal86 (01-20-2013),
guy (01-18-2014)
Turbo- and supercharged engines are usually programmed to inject a rich mixtureat WOT, to prevent detonation. As was previous said, too rich is safer.
Backfire after WOT is caused by the management system retarding the ignition. Consequence is that the ignition of the mixture is still going on when the exhaust valves open. This will also ignite any unburned mixture that was thrown into the exhaust after WOT. That's why you see flames in the exhaust after closing the throttle.
This is not something related to defects or a specific car (brand). It's by design.
amcdonal86 (07-26-2013)
It really only happens when I rev it hard if I haven't revved it to redline for a couple weeks or so. It must just be worse because of carbon buildup that occurs when I'm driving it very gingerly. Also my commute is only 2 miles so that's probably causing more carbon buildup as well.
After I "clear it out" there is no more smoke.
Mine does the same. Usually if i have been doing town and sedate driving for a while. Once i have floored it once or twice its cleared its lungs out. Maybe a cleaner put through every now and then can't hurt. Most fuels nowadays have additives in them but i still run a cleaner through every 3 or 4 mths.
KarimPA
09-12-2015 08:15 AM
