Snow Tires on XKR Portfolio
Frogdogfan, does your XKR175 have Alcon brakes? I know your calipers are painted red, but are the front calipers 6-piston with 15.75" rotors? Here's a photo - note the rotor's crescent-shaped vents.
dd823, the only way to know for sure if 19" wheels will fit is to try them before you buy them. I doubt they will clear the calipers, but I'm not positive. Putting winter tires on the OEM 20" rims should work. Used rims are usually available cheap on eBay, but buyer beware. Also check TireRack.com to see if they have a wheel/tire combo for your car.
dd823, good luck with your winter wheels/tires. Let us know what you decided to do.
Quebecjag
09-10-2015 06:06 AM
