And so it begins. Hood not latched
Well I’ve had my 2010 convertible for about 2 months now. This is my fun car so I’ve only had it out 5-6 times. I got in it today, started up. Then hit the top down switch, front windows down, back windows down then nothing. A little clicking and Hood Not Latched come on the dash.
The rear windows will not go up now and the top doesn’t move. Guess I’ll be heading to the dealer unless it’s an easy fix. Anyone have a suggestion or want to come over and make a little money.
Good luck 🤞
Read these threads:
https://www.jaguarforums.com/forum/x...-close-178209/
https://www.jaguarforums.com/forum/x...issues-119015/
Forum member WhiteXKR is the expert on convertible tops.
Learn to use the Advanced Search function. Many questions have already been asked and answered.
Your problem is very simple...your battery is not providing full voltage to the various modules. When this happens, symptoms exactly like you are describing happen -and they can be random symptoms, warning lights, windows, door locks, roof.
,tou ch screen not working properly. If you are not using this car daily, get a CTEK battery maintainer and use it whoever the car is not being driven. Thresult will be zero electrical issues.
https://www.jaguarforums.com/forum/x...anyway-197128/
Received 2,012 Likes
As stated above, check your 'luggage cover'. Doesn't take much to cause the magnetic switch to think the cover is not in the right place.
I stopped to pick up a pizza once, stuck the box in the trunk, hopped in the car, and the top wouldn't open. I had bumped the luggage cover just enough to disengage the switch.
Fiddled around a bit with the cover, closed the trunk, hit the switch again, and the top opened.
If that doesn't work, and you don't have Steve's Remote Top Controller installed, try holding the button a looonnnnggg time (more than a minute), to see if it will move.
dcarr
09-30-2016 06:47 PM
