So I discovered something today about the seatbelts...
So my seatbelt had twisted around so that the part that plugs into the buckle was facing the wrong way, which caused the belt to be twisted when I buckled myself in.
I was gonna try and twist the belt and pull it through the plug so it at least would not not twist the belt but could not get the belt material through it by folding it over and then trying to pull it through.
So I started trying to figure out how the belt got twisted to begin with. I started looking at where the belt comes out of the side panel behind the front seat. I pulled the belt out all the way to a stop, twisted the belt over, and let it go back in and the belt simply spun around and went back in normally! Apparently the end of the belt that wraps around the parts inside the panel is on some kind of swivel that twists around.
I thought I was gonna have to remove the seat and remove the bolt that holds the belt down in the floor board.
My apologies if should have known the belt did this...some of you may already have known about this...
If your mechanism is not working that way then you probably need to replace the winding/spring loaded mechanism.
Don't know...I think what I may have done to twist mine was to pull it all the way out when I was moving the seat forward to clean it. I probably moved the belt enough so that it "flipped"over...
ejjbee (03-21-2014)
Bob Gelston
09-14-2015 11:08 PM
