Solar BA5-100-1200-CCA Battery Tester
Having low battery problems?
I bought a Solar BA5 battery Tester. It is totally digital, great readout. The Solar BA5 with test for CCA efficiency. This tester will tell you if CCA is down and if a cell is bad within the battery.
So easy to use, nice readout. Test battery in seconds. Just hook to battery, no batteries needed in device. It powers itself from the car battery.
Worked great,. I got the item idea from another forum member "Hawaii". Thanks for the tip. I watched the video and placed my order. Tested 4 car batteries today.
Now I know my Jaguar battery is good. I do keep a CTEK 3300 attached when not driving the car.
Check out this automotive item for under $47.00.
CTEK also sells the same type of device only at about $85.00.
TFlan (08-16-2014)
Jzar
09-27-2015 02:55 PM
