Sooo.... I got carjacked....
#81
#82
#83
#85
I'm still in shock. I've attached a summary I used for the insurance company of the work done.
FYI, the rear crossover pipe was replaced about a month prior to the theft.
My next two issues would have been:
- keep hunting the phantom power drain (gotta start that car dialy)
- supercharger is getting a little knock-y.
bogdanfilip (08-05-2022)
#86
Here ya go:
2010 JAGUAR XKR SHOP WORK
(DOES NOT INCLUDE MAINTENANCE - TIRES, OIL, FILTERS, FLUIDS)
09/16 REPLACE #1, #6 FUEL INJECTOR
REPLACE FRONT LATERAL ARM BUSHINGS
REPLACE #2 COIL
10/16 INSTALL SPACER AND O-RING TO ELIMINATE WHISTLE IN FRONT CLIMATE SYSTEM
REPLACE REAR TRUNK LID TAILLIGHTS DUE TO DEFECTIVE FOGLAMPS
04/17 REPAIR SUPERCHARGER USING SNOUT KIT
REPLACE A/C DRAIN TUBE ASSEMBLY
REPLACE TRANSMISSION MOUNT (1)
06/17 REPLACE ELECTRONIC DIFFERENTIAL- UNIT SHIPPED FROM UK
03/18 REPLACE RIGHT AND LEFT REAR WHEEL BEARING
REPLACE BOTH UPPER FRONT CONTROL ARM BUSHINGS
REPLACE SWAY BAR LINKS
04/19 REPLACE BOTH FRONT WHEEL HUB-BEARING ASSEMBLIES
REPLACE ENGINE MOUNTS
10/19 REPLACE CONTROL MODULE
REPLACE FRONT SWAY BAR BUSHINGS
REPLACE LOWER REAR CONTROL ARMS AND BUSHINGS
REPLACE HEADLAMP CONTROL MODULE
11/20 REPLACE COOLANT FAN AND SENSOR ASSEMBLY
REPLACE THERMOSTAT ASSEMBLY
REPLACE WATER PUMP
REPLACE RADIATOR HOSE (2)
REPLACE/REPAIR WIRING FOR CONVERTIBLE TOP
REPLACE CONNECTOR PIN ASSEMBLY FOR CONVERTIBLE TOP
REPLACE BOTH FRONT INNER STRAIGHT ARM BUSHINGS
06/21 REPLACE BOTH FRONT ADAPTIVE HEADLAMPS
REPLACE DRIVE BELT
REPLACE VACUUM PUMP
REPLACE FRONT CURVE ARM BUSHINGS
08/21 REPLACE A/C COMPRESSOR
10/21 REPLACE COOLANT MANIFOLD, REAR HEATER HOSES
TOTAL: $48,888.59
REPLACE #2 COIL
REPLACE WATER PUMP
REPLACE DRIVE BELT
REPLACE VACUUM PUMP
TOTAL: $48,888.59
#88
The following 2 users liked this post by 89 Jacobra:
bogdanfilip (08-05-2022),
pk4144 (08-03-2022)
#90
Received 1,177 Likes
Here ya go:
REPLACE #2 COIL
REPLACE WATER PUMP
REPLACE DRIVE BELT
REPLACE VACUUM PUMP
TOTAL: $48,888.59
REPLACE #2 COIL
REPLACE WATER PUMP
REPLACE DRIVE BELT
REPLACE VACUUM PUMP
TOTAL: $48,888.59
#91
Replacing 2x headlamp units at USD ~3,600 each is "maintenance"? Wow.
As for most of the rest, that would be highly dependent on the mileage on the car at which point these activities became necessary. It may have been mentioned earlier in the thread as to how many miles the OP had on his car but I must have missed it.
Being an active follower of multiple car marque forums (all of them "cars with personalities" BTW) it is interesting to me as to the level of problems and consequent maintenance/repairs that owners find to be acceptable. I think Jaguar owners are particularly tolerant...
The following 2 users liked this post by ram_g:
DGL (08-04-2022),
resident_fng (08-04-2022)
#92
#93
I’m sooooo happy to see that huge list ))
yeah , I’m so happy with the car , drives amazing …
now I hope I can find a good body shop that can fix that damage .
#95
#96
