Speaking of inflator kits...
Redrider:
If your going to drive your XKR without a real small spare tire and keep just the inflator kit, I will suggest a few aftermarket items to buy.
1) Buy a small mini sized air compressor that plugs into a 12v outlet or cigarette lighter. Also a Accutire Digital Air Gauge.
Digital Accutire Air Gauge: Accutire Standard Car Digital Tire Air Pressure Gauge Auto Tyre Truck Tester PSI | eBay
2) Buy a Tire plugging kit that comes with supplies to "plug" a tire if flat. They are frequently used for ATV's, trailer tires, auto tires.
New 35pc DIY Flat Tire Repair Kit Car Truck Motorcycle at Home Plug Patch Set | eBay
Buying items #1 and #2 will provide peace of mind if your stuck with a flat tire caused by nails, spikes, screws etc. You would be able to repair the car tire on the road. These items will not help a sidewall blow out, nor would the Flat Tire can of inflator foam. Most flats are caused by spikes, nails, screws etc.
My 2014 Porsche Cayman does not have a spare tire, so I carry items #1 & #2 in the car storage at all times with a pair of long nose pliers to pull out any spikes, nails, screws etc.
You probably don't have road side assistance, because your car is not covered by any Jaguar warranty, unless your current auto insurance covers RA.
The Flat Tire inflator foam will get you only so far, and may cause additional damage to the tire and rim, especially if you have to drive a longer distance for potential tire repair. With the Tire Plugging kit, you can repair and drive long distances or days, then ultimately have the tire looked at. You will also have the mini air compressor to properly inflate the tire to normal air pressures, and finally you have a digital air gauge for accuracy of tire pressure.
If getting a flat with a nail, screw, spike, etc, most tire shops simply plug the tire anyway. Some will dismount the tire from the rim, apply a plug and an inside patch.
These items #1 and #2 really work and I strongly feel it is a wise option for under $50 to have the potential to make a quality repair if stuck on the road without RA.
It's really a safety issue. You can buy a can of tire inflator foam at any autoparts store or even Amazon.
RedRider48 (06-09-2014)
Great post Rich, thanks! I've fixed many a tire here in the garage and have those plug kits. Yes, this is my first exposure to "no" spare tire. I do have AAA with a 200 mi radius towing plan. One nice thing, there is plenty of room to store those suggested components. Got to thinking about the 12V inflator...with my luck, I'd kill our already "weak" battery/ charging system in the process LOL!
Happy Trails......
Happy Trails......
My XKR came with a little 12V inflator along with a can of goop. It's a small black plastic box - might pay to have a closer look behind all sides of the boot well liner. Mine is tucked under the lip of the boot, where the latch is.
The inflator works well enough - had a slow puncture recently, and it was able to get the tyre inflated to get me home. I didn't bother with the goop because I only had a couple of miles to travel, and I was hoping the tyre would be repairable (no such luck, ouch!).
Jaguar Forums Editor
Jaguar Press release
09-28-2015 05:18 PM
