Spires Group Purchase
Evoking reminded me last night about the group buy from Spires. I'm currently having them build me a set of Coilovers using Modified F-Type Dampers and Eibach springs that are fully compatible with the Adaptive Handling System in our cars.
If anyone else is interested in anything they have please let me know so that I can find out how many people are interested which has a direct correlation to the discount we can receive. I'm not sure of the amount yet but my price is 400 pounds lower than the advertised price. Keep in mind we still have to deal with VAT unless someone knows a way around it.
Let me know and have a great day,
Max
Max
Max
Max
General overview - European commission
Here is some good information. You should not have to pay VAT. VAT is for European member countries only. It's like buying online and not having to deal with sales tax here in the USA. I have a re-seller's license if you run into any problems. That will help with one here or there but I don't think I'm comfortable floating and group buys...
For the purpose of exports between the Community and non-member countries, no VAT is charged on the transaction and the VAT already paid on the inputs of the good for export is deducted - this is an exemption with the right to deduct the input VAT, sometimes called 'zero-rating'. There is thus no residual VAT contained in the export price.
However, as far as imports are concerned, VAT must be paid at the moment the goods are imported so they are immediately placed on the same footing as equivalent goods produced in the Community. Taxable people registered for VAT will be allowed to deduct this VAT in their next VAT return.
A study provides detailed informationpdf(980 kB) Choose translations of the previous link (in English only) on the import VAT payment rules in different Member States.
There testing was done on other customers XKRs. If you want the XKR dampers I'm sure they will modify those for you as well. There is no manual adjustability other than what the ADS provides. They just modify the valving for the spring rates you desire and also modify the bump stops in the shock so you don't bottom out as easily. If you want manual adjustability I don't think they will be ADS compatible at that point. PM me your email if you like and I'll loop you into the conversation with Matt from Spires.
Here is the first response from Matt at Spires. I'm waiting on the response on the damper modifications.
Hi Max,
No worries, always happy to answer questions.
Firstly the group buy. I can offer discounts on multiple buys of the same items which I can calculate at the time but would expect it to be in the region of 15%.
I would also be able to offer a 10% discount on a bulk order of parts regardless what is ordered. (3 products or more).
I can send all items to USA excluding VAT, but be aware, your country will almost certainly apply an import / sales tax.
Matt
Spires
Hi Max,
Matt
Spires
If they simply ship in the mail then you are supposed to seek out the authorities to voluntarily pay import tariffs. If you're not doing a ton of transactions then nobody will ever care. In other words - I am going to be in Europe in a couple of weeks. If I send you a package then it just gets delivered, right? I am going to send some chocolates to my fiancee. Same thing. Customs is not going to open every box and research the price of everything that comes over. If you're really worried then have them send the invoice separately. Just nod that you understand that you are supposed to pay the taxes... It's really not a big deal for consumers.
MaximA (01-09-2014)
Here are your answers on the damper questions.
Max,
The dampers are subtly different in rebound and compression forces (circa 5% stiffer at higher forces and 5% softer in the lower forces). This will help with traction on slower bends and pull away, but give more ultimate control when driving quickly.
It's more the increased spring rate which will give the most benefit to the handling performance. The front spring goes up to 100N/mm from 79N/mm and the rear increases to 120N/mm from 95N/mm.
If your friend is nervous about F-Type damper, then I can do the same package but with the XKR damper, the gains are not so good, but it does work well.
I have sent many orders to USA and always send them excluding VAT. Typically customers just pay sales tax.
Hope this helps?
Matt
Spires
Max,
Hope this helps?
Matt
Spires
ok my order is in with no VAT, evoking just email Matt at info@spires-st.com and tell him you spoke with Max and he will hook you up with the 10% discount and no VAT.
R_rated you just saved me $700.00 Thank you!
Here is their XKR.
The car just seems to stick really well, and gets the power down out of the corners much better than a stock XKR(s)
http://www.youtube.com/user/SpiresTuning/videos
axr6-If your around I spoke to Matt at Spires about the sway bar and this was his response.
There isn't a stock replacement rear bar for your car and to be honest, I'd suggest you try the coil over first. You'll be amazed at the difference. The increased rear spring rate really makes a massive difference to the handling balance. I've ran this set up at Germany's Nurburgring and in Spa - Belgium and it it truly awesome.
We can look at GT rear bar but the price is steep... Hopefully I get everything installed, the car corner weighted and aligned before autocross here in February to see how this setup handles. the sway bars i mentioned before were for a 2008 model.
Does anyone know if the current XKR-S has a larger rear sway bar then the XKR?
