squeaky suspension
J.A.G. (04-11-2022)
Your XKR is 9 years old and the original rubber bushings have dried out and some may be cracked, which will degrade handling and make clunking and squeaking noises. You can postpone the inevitable replacement of those bushings with a cheap and easy DIY fix using a can of spray silicone lubricant to saturate all of those rubber bushings. That's a band-aid, not a joint replacement. But it might stop the squeaking. It's worth a try for less than $10.
Thanks Stuart.
Its worth a try... Ill put on the band aid for now.. but will look for a permanent solution as well.
Patrick Kelly
05-19-2016 12:04 PM
RRT
02-07-2012 06:01 AM
