Stained wheels
Stained wheels
My 2010 XKR has some staining on the alloy wheels. It looks like burned in chemical stain or something, maybe from heated brake dust or greasy fingers. I have used wheel shine/cleaner and used a rotary brush on a drill. Cannot remove. Any ideas what I can do to get this off? I am shying away from acid cleaners, as I have heard them creating more stains than what you start with.
Thanks.
Thanks.
If proprietary products won't do it then take it to a specialist, there are a few in Tulsa, this is one:
https://curbrash.com/best-audi-bmw-l...el-rim-repair/
If the repair is purely cosmetic it should be relatively cheap as they'll not have to skim any of the surface off, just acid dip and relacquer
So many possibilities here, both as to cause and cure. Mark's advice is sound if you don't want to go further yourself. I would check to see if they would give you some free advice in any event.
If you want to try other things yourself, it would help for you to post pictures.
Best of luck.
Best of luck.
peterv8 (10-27-2020)
Received 1,179 Likes
But the wheels are painted. I suspect the paint is permanently damaged.
I never use the wheel cleaning products. A soft sponge, warm water and a little mild detergent is all it takes.
But I am amazed at the number of cars with permanent discolored wheels; my assumption is some chemical reaction and scaring took place.
