Stance setup help for 07 XKR.
Ground clearance
Pacio, nice work looks great!
I've added the R-S front splitter to mine and I'm hesitant about putting on lowering springs.
Can any of you guys that have added lowering springs tell me what your ground clearance under the nose is now?
Please specify if you've added the splitter too.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
You can get the H&R spacers 15mm and 20mm sets as well as the -35mm H&R springs from LarkSpeed UK, i personally recomend Lark used them for ages never dissapointed.
I have made up some amateur comparison pics here goes :P
And the next one shows the car with new reg plates color coded jaguar strip debadged and with the suspension mods i think it looks meaner now
I have also recieved some of the parts ordered and will start putting them on tomorrow
Oh and if anyone is interested i can get another full set ( all 4 pieces) of brand new never used genuine jaguar rear LED taillights for around 350-400GBP
Also i can get a complete modified harness that has all the needed modifications to make sure you get no bulb out errors on the dash and both reverse lights working like they should.
Well thats about it still waiting for the RS diffuser, and the sideskirts, and the splitter, and new intake and.........here we go again
Mike V (04-12-2012)
Pacio
Great looking mods!
Some questions, please;
1) Did you suspension EVER bottomed out with the short springs under street/highway driving? (not considering going over speed-bumps) Please, anyone who lowered their cars chime in on this important question.
2) When the springs were installed were the damper rubber "bump-stops" shaved to compensate for the reduced damper travel?
3) Did you have to cut the wheel studs for the 15 mm H&R front wheel spacers as suggested by the other poster? How about for the 20 mm?
4) What "little mudflaps" are you referring to when it comes to rubbing at full fuel/passenger load? I don't seem to find any mudflap to fit the description on my car. Is it the plastic wheel-well cover over the wheel?
I really like the way your lowered car looks but, still concerned about the dampers bottoming out and destroying themselves, as well as the alignment issues. Right now my tire wear across the tire-thread is about as perfect as I have seen on any car.
Thanks,
Albert
Great looking mods!
Thanks,
Albert
Pacio
Great looking mods!
Thanks,
Albert
Great looking mods!
Thanks,
Albert
2) NO
3) NO my standard jaguar wheels had cutouts inside the wheels to accomodate the studs that ware sticking out and i think they ware like that from the factory. But if you have wheels without these cutouts, then yes you would have to cut the studs, or drill the wheels.
4) im refering to these little plastic bits on the wheel arch
I have no regrets since installing the suspension mods even guys at jaguar dealership in manchester said this is the way xkr should look from the factory lol
Pacio
Great looking mods!
Thanks,
Albert
Great looking mods!
Thanks,
Albert
Since then I have lowered 4 cars and can't drive a car without it. To prevent issues, I go no lower than 1 inch and keep the stiffness no more than 5 - 10% over stock spring rates.
We're not kids trying to slam the car but I hate the gap usually seen with stock cars. I enjoy coming off the interstate at high speed, going around the exit curves like a roller coaster...hugging the road. I like making right turns at 20 mph. I enjoy making high speed lane changes on impulse with little body roll.
This is with a big sedan. I can't wait to drive a lowered XKR.
Yep, once you lower a car you will always do it! Pacio, we need more quarter angle pics of the whole car.
I'm going to order some spacers and springs. So the Ebay spacers you posted won't work? Where did you get the H&R spacers and wheels? Wish I got more responses from my Springs Comparison post to understand the variance of harshness between them. The Mina's seem to be the cheapest at around $300 or so.
#30
Got it from my local Jaguar Dealer, comes painted and with the leaper on all i did is install it today and looks amazing you don't notice big difference on pictures but in life looks really good. Took me 30 min to install it and im no mechanic, all you need is a T20 torx bit with a hole inside it as the screw has a little pin in the middle, a standard T30 torx and some cloth and water to clean the surface.
#33
I'd be worried about going quite that low but, no doubt the car looks great. You're right, this is how Jag should have filled those wheel wells right from the factory. Not sure why they decided to leave those big gaps, almost like they expected people installing chains over the tires in the winter... maybe they did?
I ordered the 4x20mm spacers. The 15mm that you used on the fronts were not even listed by H&R for this application. I measured and figured that the 20s would work up front. Can you think of any reason why they should not?
Thanks for the write up and pictures. Your car looks fantastic.
Albert
Albert
#37
I went with Paramount Performance UK lowering springs which are about an 1 inch drop (25mm). There are some more aggressive springs that are 1.5 inch drop but didn't wan to go that low. In the past, I've lowered my C5 Corvette (lowering bolts) and Mercedes (lowered by star diagnostic programming with the air suspension) and had no problems. Typically it does ride harsher but I lower it so it doesn't have the 4x4 look. I go over speed bumps all the time with the Jag at the club with no problems and I do angle in and out of the driveway due to the fact I also have a front splitter on my XKR but you just have to go slow. I've had the lowering springs for 2-3 years now. Here is the PP lowering springs.
Near the end of my friend's vid in my sig below...you can also get a sense of how much of a drop with the PP springs.
#38
xkrsupercharged i cant send you a pm for some reason,
If you are interested i am coming down to london tomorrow ill be at quensway area for a few days so i can take the taillights with me. Its 370GBP for a full set, these are genuine jaguar and brand new.
If you make up your mind please mail me at fireburns7@gmail.com ill send you my mobile nr, cheers
Patrick
Patrick
#39
Yikes! According to that link the spacers are $127 a pair. Nearly $300 for all 4. I think that's a bit much. Especially since I plan on getting wheels anyhow it would be like throwing money after bad.
I thought they were much cheaper... Also, Pacio who did you use to install them again? I wonder if I should be concerned about using the dealer... If they know I put lower springs on then if my shocks go they may not cover. I have 5 years maintenance on the 11'.
#40
I all depends on your relations with the dealer, i have 2 years warranty left on my xkr and they did not mind my new exhaust and suspension mods, i have asked them prior to mods if ots ok and i think thats the way to.
