Stance setup help for 07 XKR.
#61
Yeah its nothing difficult although the fit is not perfect on this picture i had it corrected 30 minutes later now its flawless, same with LEDs took me around 2h from start to finish to do all 4 lights.
I will be fitting the front splitter, carbon fibre side vents and new style chrome "supervharged" stripe bonnet vents this weekend hopefully wash the car and upload some better pics then.
#62
Thats awesome!! Quick question about the lights. Did your new style lights come with fixing bolts and washers etc or did the ones from the old style lights fit? Also did you use the Adamesh wiring looms if so did you face any errors with the reverse light and fog light issue resulting in needing additional relays??
Can I also ask where you picked up the rear splitter from it looks awesome!
#64
Spacers on the XK
Today I installed the 4 x 20 mm spacers on my '08 XK with stock springs. Here are my comments:
Not sure what, if any, offset differences exist between XK and XKR wheels but, for the XK the 20mm is perfect for the front. For the rear, the ideal thickness would be more like 10mm as the 20mm lines up too much under the fender lips. There is approx. 2.5" of wheel travel, while maintaining the same camber, before the tire contacts that fender lip. That is quite a bit of travel and, I think, more negative camber would occur at that compression, so, I am not very worried about it touching. I drove about 15 miles on the spacers, some tight, fast winding roads and no touching, thus far.
As far as looks, I called my wife, who normally would have a hard time telling if a wheel had fallen off a car, and I asked her for impressions. I told her that I put spacers to move the wheels outwards. She walked around, looking and kind of made a move to simulate a bodybuilder flexing his lats. She said: "it's like... wrooooommmm... more muscle-ey...". Yeah, I answered, us, Tarzans, like muscles, period.
Yes, the car definitely looks more aggressive with the wheels out.
Driving: Definite improvement in cornering feel. I could tell in the very first turn and in every subsequent turns that the car was more composed during cornering as well as during transitions, feeling as if it had less body roll and more support from the sides. Well, no surprise, after all the track width just increased by 1.5" total. Still the same bothersome understeer but, the car is more confident in the corners. Using 20mm front and 10 mm rear would probably take away some understeer, as well.
I had enough wheel indents to accommodate the original lugs after mounting the spacers. Likely the indents would not be enough to accommodate the same lugs if less than 15 mm spacers were used. Of course, likely, 10 mm is not even an purchase option as it would not be able to countersink the special mounting nuts. If I did this again, I would purchase the 15mm for the rears.
Ride height is close to the same, maybe 1/8" lower, due to a longer total suspension lower arm length acting on the springs.
Conclusion: Will keep an eye on the rear fender contact, if any. Besides that the results are all positive, improved handling and improved looks.
Albert
Albert
Mr_Nico (12-12-2016)
#65
That's great Albert. I am gonna do research on on this for my XKR.
Also keep an eye on tire wear - doesn't sound like this will be an issue though...
I laughed at that comment from your wife - mine is about the same...
Albert
Albert
#66
Albert
Albert
#67
The only difference worth considering is the wheel offsets, that is, how far out are the outer edges of your wheels as compared to my stock wheels. Likely, they are also very close or the same, if your wheels are also stock.
You can make a quick check for fitting. Use a longer, say 3 feet, straight water bubble leveler and set it vertically between the level ground surface and the outer edge of your wheel cutout. Measure from this vertical level how far INWARD is the most protruding portion of your tire. From that measurement you will get an idea as to where it will be with the spacers.
Albert
#68
#69
Wheel size, as far as diameter, should NOT have any effects as the 20s" are within a very few millimeters to the 19s". The wheels may be 1" larger in diameter but, the tires have about 1" shorter sidewalls (2x0.5") to make up for the difference.
Albert
Albert
#70
This is where I got them from:
H&R Wheel Spacers For Jaguar Cabrio 2007-up 20mm (4035633)
Took a little more than a week to receive them.
Albert
#71
Albert
#72
#73
Do note that yesterday I did look at my rear wheels to see if they would accommodate the 15mm spacers with NO modifications to the stock wheel mounting studs. Since I could not see inside the mounted wheel surfaces, I reached through the wheel spokes using a 5mm-thick special tool to see if there was still enough room between the studs and the back of the wheel. There IS NOT. The remaining gap is only about 3mm so in my particular application a 15mm spacer would require cutting a few mm off each stock wheel studs. The same was reported by an other forum poster when he tried to use the 15mm for his front wheels.
Albert
#75
If you have the right cutting tool, cutting a few mm of the smaller diameter starting threads off the stock studs takes a few seconds and will hurt nothing. There will be plenty enough thread left for any mounting purposes.
Albert
#76
Bruce
#77
I mistook post 54 where it lists the links and the name of the company H&R Springs for it saying a link to the springs themselves
Ok. So I am in fact back to the Mina's or Paramount. Mina's are cheapest, stateside and I've heard they ride good so perhaps I'll just go with them... I had H&R's on my NSX's and liked them so was hoping they made some. Oh well...
#80
If I were still in the Navy I would say, "Out-f*(*)ing standing!!"
I might date you if you were here with that car. ( ha ha )
That shot of the back is magnificent.
And you put all the parts on yourself? Great job.
